The e-Ram Electric Supercharger
Old Jul 5, 2008 | 03:25 AM
kuwait_G35's Avatar
ANY info about this product ????
http://www.electricsupercharger.com/products.html
plz let me know
i 'll be so thankfull
Old Jul 5, 2008 | 03:37 AM
joedaddy1's Avatar
it blocks air flow.
/close thread.
Old Jul 5, 2008 | 09:33 AM
Texasscout's Avatar
Do a boolean search for "Electric Supercharger" (with quotes) and you will come up with lots of bad stuff on them.
Old Jul 5, 2008 | 11:33 AM
kuwait_G35's Avatar
thanks so much ..
sorry for noising you
Old Jul 5, 2008 | 01:25 PM
Locksmith's Avatar
wack
Old Jul 5, 2008 | 07:00 PM
G37Rider92649's Avatar
Uh.......are you serious?
But not to be a *******...umm...No
Old Jul 5, 2008 | 08:40 PM
badtziscool's Avatar
That company is so amateur. They bolded the amount of wattage and amperage the unit draws as if more is better.
A typical alternator can produce 120amps and this thing draws 124amps?!!? That leaves nothing left to power other stuff, like, oh, you know.... Spark plugs, fuel injectors, fuel pump, head lights, gauge cluster, throttle body, ecu, and other non critical sensors like tps, o2, egr...
Old Jul 5, 2008 | 10:25 PM
Texasscout's Avatar
What are you talking about? The e-Ram "Electric" supercharger draws less than 5 amps. That's why it won't work at anything over 2000 RPM, it can't move enough air.
Now if you mean the that huge electric supercharger using 3 electric motors and a Roots type supercharger, yes that draws upwards of 120 amps. HOWEVER, if you read the article, you will see that they have installed three huge batteries and a dual charging system to handle the load. That supercharger can't go more than about a minute or two before it runs out of juice and must be recharged for 15 or 20 minutes.
Old Jul 6, 2008 | 04:56 AM
Well. Regardless, it's still a POS. I was just reading what they wrote on the first page of their website. I didn't even bother with reading anymore than that.
Oh. And you need to change your avatar. Hillary is out of it now. Thank god.
Old Jul 6, 2008 | 07:39 AM
Texasscout's Avatar
Yes, it is a POS, there is only one Electric Supercharger that works, but it's a PITA to install and very $$$$$.
As for the avatar, don't count the Bitch out until AFTER the convention. Something in the back of my head says "something" is going to come out just before or during the convention about BO (Ha! I always thought he stunk!) and the Super Delegates will have to give it to the Bitch. We'll see.
Also, I can't change it, I'm not a "premier" member anymore. If I remove it, I can't put a new one in it's place.
Old Jul 7, 2008 | 05:01 PM
OCG35's Avatar
I'm not premiere any longer either... just blend in with the rest of us common folk
Old Jul 7, 2008 | 05:29 PM
5150DS's Avatar
Here is an electric supercharger review from Turbo magazine: http://www.turbomagazine.com/tech/04...ger/index.html
Here is the company web site: http://www.boosthead.com/home.php
Old Jul 7, 2008 | 05:34 PM
Texasscout's Avatar
This is the ONLY Electric SC that make any power.
Freeman186
Sep 6, 2023 10:07 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
vamarris
Sep 26, 2015 12:56 PM
