bogging out(assistance please)
hey guys/gals maybe you can help a fellow g owner. i have an 05 coupe,procharged. last sat night i unfortunatly got caught in some HEAVY rain,and my filter for my procharger faces the front of the car,so cold air can be forced in,well the car started bogging out the night of the rain and i figured it was due to the filter being wet,its been 5 days now since ive driven the car last and when i started the car today and tried to drive off..its bogging out again..and the car wont rev over 2500 rpms..and when i give it gas,it tries to die on me...anyone have any idea what is causing this could it be fuel pump,plugs?...your help is appreciated
Guest
Posts: n/a
MAF does = Mass Airflow Sensor. If it gets some debris on it, it can cause the car to act funny.
There is also a gromet with several wires running through it on the passanger side of the engine bay, I think kind of under the windsheild, and where water drips down between the window and hood. Check to see if it got wet. It can also cause strange problems with the car.
Car could also be in limp mode. You should be disconnecting the battery to try the above anyhow, so just leave the car disconnected over night and it will reset the ECU. Then see how it runs.
thanks man ill give that a try..i appreciate the help..i know infiniti would prob charge an arm and a leg to look at this thing...thanks again..if this works ill let you know the results.
well i figured it out..turned out to be bad gas i got at a chevron,i had a buddy come over he said i prob have a clogged injector we put some lucas fuel injector cleaner in and seems to be running normal again...thanks homieg for the help
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Rhinos7777
Sep 6, 2015 05:36 PM
