my oil change questiosn... 15w40 alright?
I picked up some mobile 1 high performance oil (for high performance vehicles) and its 15w40. I live in florida so it almost never gets cold... i also picked up a fram tough guard oil filter... do these seem alright? or should i switch the oil out for something more along the lines of 10w40 or 0w40?
i would say that you should stay within factory recommendations for oil. 15 weight oil doesn't circulate as fast as 10 weight oil on cold start (not temperature related). also,, you reduce hp by increasing viscous drag in the engine.
A manual from the dealer or ebay. Or read the huge oil thread on this site. Resolute I believe posted it. Engine section
5w30 is recommended across the board. if you live in warmer temperatures, you can substitute 10w30. the number in front of the w is cold viscosity, and the second number is operating temp. viscosity.
