Where to get car tuned in Maryland
Old Jul 22, 2008 | 02:32 PM
seung012's Avatar
I have a fully built NA G35. I got a utec and I'm trying to get my car tuned. I called functiontuned and they don't seem to answer. Chris at Elite Importz called TurboXs in Gaithersbug and they can do it in the first week of August but want $450.00 Flat for 2 hours of dyno time and 1 hour on the road. I don't want to go to JE.... Any suggestions? I'm in Laurel, Maryland.
Old Jul 22, 2008 | 02:34 PM
seung012's Avatar
And if you are wondering why i'm not boosted yet, i'm wanting to see what my car does all motor first. With cams, 111, 3.6L, and all botlons, it should be interesting.
Old Jul 22, 2008 | 02:36 PM
r0csfinest's Avatar
leave a message at FT or something.... they never pick up when i call either... i guess thats how busy they are. but thats who i would say go to
Old Jul 22, 2008 | 02:57 PM
Skaterbasist's Avatar
Retired SuperMod
Try asking in the regional forums.
Old Jul 22, 2008 | 02:58 PM
Klubbheads's Avatar
can u list everything that u have right now?
Old Jul 22, 2008 | 08:39 PM
seung012's Avatar
Wiseco Pistons 96mm/11. 0 : 1 Pistons
Eagle/SCAT H Beam Rods
ARP Rod Bolts
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated Race Spec main bearings installed
New Moly coated Race Spec rod bearings installed
Block assembled
New OEM Head Gaskets
Heads inspected and cleaned
Heads redecked
Ported exhaust and intake runners
Oil Pump - VQ35 RevUp
JWT S2 Cams
JWT Heavy Duty Valve Springs
5 angle radius cut valve job
New OEM Valve stem seals installed
Valve Stem Heights set
Cold Clearance set for stock cams
Heads assembled
New OEM Rev-up Oil Pump
ARP VQ35 Head and Main Stud Kit
Z-tube
JWT popcharger
Copper iso thermal spacer
Strup Headers
Strup Testpipes
Fast Intentions exhaust
Unorthodox Pulley Kit
ACT HD clutch and pro lite flywheel
Old Jul 23, 2008 | 11:18 AM
Klubbheads's Avatar
wow.. how much power are u putting down right now?
Old Jul 23, 2008 | 07:17 PM
superchargedg's Avatar
Im not going to tell you again.Also pm me your cell number.
Old Jul 23, 2008 | 07:19 PM
mIKE's Avatar
Altered Atmosphere?
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
sick_sixspeed
Jul 20, 2015 10:25 PM
Chattzx
Jul 17, 2015 11:23 AM
quickspeed6
24
Jul 15, 2015 11:06 AM
