Cleaned TB..Now the car heaves
Old Jul 27, 2008 | 03:04 AM
GD-Up's Avatar
Hey all,
Wondering what could be wrong. I cleaned my throttle body the other day. I disconected the sensor input and the Neg- battery before cleaning. Then cleaned out the TB...and yes I did open the move the flap when cleaning.
Usually when you let off the gas the car pulls back a bit...now that heave is a lot more prominent and it really lurches. The lurch is delayed though...you let off the gas, wait 2 sec's then the lurch comes in. I also noticed ( but i think it is gone now) that the RPM increase a bit when I push in the clutch???
Any suggestions?
Old Jul 27, 2008 | 03:19 AM
GD-Up's Avatar
I was scared of that.... this dealer here doesn't do anything for free!!
Live and Learn i guess!
Thanks!!
Old Aug 4, 2008 | 09:13 PM
maxpusher's Avatar
20 Year Member
I had the same problem. Check out my fix and see if it works.
https://g35driver.com/forums/intake-...g-now-cel.html
Old Aug 5, 2008 | 02:28 AM
GD-Up's Avatar
^ Thanks Man!! I have will definately try that...I have done the relearn with no luck..but like you said, Timing is key.
I have a used TB on the way just incase though.
Old Aug 5, 2008 | 09:01 AM
Q45tech's Avatar
Study synchronous electric motors and hysteresis to understand how you screwed it up.
If members would just disco battery before fiddling with sensor.
Old Aug 5, 2008 | 02:53 PM
GD-Up's Avatar
Funny thing is, it did disconect the neg terminal
Old Aug 11, 2008 | 11:06 PM
bythabay's Avatar
confirm the CEL actually blinks and then stays solid when you are doing the re-learn. Otherwise whatever you're doing is ineffective.
Old Aug 12, 2008 | 02:52 PM
nismotech1's Avatar
i recommend going and having the dealer do an IAVL reprogram which is idle air volume learn. and it should solve your problem unless you need a new throttle body assy, now as far as i know you can get a reman from the dealer for around 140 bucks and then you have a warranty with it as well
rambo
Old Aug 12, 2008 | 04:42 PM
bythabay's Avatar
rambo
I think that is not necessary as the same procedure is outlined in the FSM and can be performed at home for free without any equipment.
Old Aug 13, 2008 | 11:02 PM
GD-Up's Avatar
Thaks for all the info guys, but I ended up just getting a used TB. Everythings is running good...finally~
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
wojowojo16
Jul 27, 2015 09:57 AM
newg37
Jul 26, 2015 09:32 AM
