Oil Cooler O-Ring???
Old Dec 20, 2010 | 05:57 PM
US V35 Skyline's Avatar
What size socket do you need for the connector bolt? I just had a quote of 140 dollars!
Old Dec 20, 2010 | 06:01 PM
bythabay's Avatar
where are you located? I'll do it for free just to spite whoever gave you that quote! I think the socket is like a 27mm or something, i can't remember exactly. maybe a 26 or a 24.
Old Dec 20, 2010 | 06:06 PM
Denver, CO
Old Dec 20, 2010 | 06:10 PM
I'm also looking for an oil pan if anyone has one they are willing to sell, the dealer said my oil pan needs to be replaced in his words "it's crushed"
Old Aug 6, 2011 | 07:53 AM
exiledtrinib0y's Avatar
awsome i got to change mine too and i will be going to the nissan dealer instead of the infinity stealership...
Old Nov 18, 2011 | 08:21 AM
obsdnoblivion's Avatar
I took a look at the ring on mine yesterday and it looked just fine. Not corroded at all. Can it start leaking and still look like there's nothing at all wrong with it?
Old Nov 26, 2011 | 04:56 PM
Cox_G35's Avatar
Just replace the o ring. Went to Nissian and bought the part (FYI part #21304-JA11A). Changed oil while I was @ it. Replaced the belts and cleaned air filter. O ring was a snap. But my problem now is service engine soon light is on. WTF?
***edit*** Reset ECU and light went off.
Old Nov 28, 2011 | 09:16 AM
Anybody got a replacement that's black instead of orange? I did.
Old Nov 28, 2011 | 12:19 PM
Cox_G35's Avatar
Yeah. The replacement that I just put on was black.
Old Nov 28, 2011 | 01:09 PM
Cool thanks.
Old Nov 30, 2011 | 07:42 PM
dickjack13's Avatar
ttt
so what was the connector bolt socket size thanks
Old Dec 2, 2011 | 09:33 AM
Dang dude I forgot. 21 or 22 mm I think.
Old Dec 2, 2011 | 09:59 PM
dickjack13's Avatar
dang
dang so it might be 21, 22, 24,26,or 27 man i guess ill find out sooon enough
Old Dec 23, 2011 | 11:16 AM
Michael Joneser's Avatar
Did mine yesterday, it was a 22mm. I recommend using a 6 point socket or wrench not a 12 point because the head is very short and could strip. I don't know what the torque is suppose to be so I just snugged it up well.
Make sure you keep the new o-ring and inside the housing and bolt clean from debris, I cleaned the inside of my 22mm socket before using it to remove the cooler.
Old Dec 30, 2011 | 08:48 PM
  #30
2gnt2wrx's Avatar
I just replaced mine, pulled out an orange one, put in a black one. The weird thing is... The previous mechanic installed the old one wrong, It was slightly folded in one spot, causing it to leak.
The whole thing took 10minutes to install.
