only option is NISMO??
Old Aug 4, 2008 | 01:54 AM
sheplex02's Avatar
Exclamation only option is NISMO??
ok so im looking to upgrade my diff.. i looked all over the internet and found quite a few for the G35.. then i noticed that most say only for 6MT.. i own a 5AT.. now the car will be getting ALOT of work done including built trans so i thought.. "hhmmmn, yeah, i should mos def upgrade the diff" so im getting a better diff cover that cools the diff and now i need a diff.. 2 websites say that the NISMO 1.5 is the only one that can fit the 5AT.. which is ok.. i just wanna make sure is all..
Old Aug 4, 2008 | 09:58 AM
Shakuya88's Avatar
If your fine with the Nismo then go for it....But what you relle should do is sell the 5AT and get yourself a 6MT...problem solved
Old Aug 4, 2008 | 10:05 AM
sheplex02's Avatar
hahaha.. well I bought the auto cuz when its tuned right it shift quicker than the manual..
what I should have asked "is there a problem with the NISMO diff or is it a primo unit?"
Old Aug 4, 2008 | 01:39 PM
_jb's Avatar
_jb
Photographer
It's not actually the automatic transmission that causes the diff to be special, it's the rear end gears associated with cars with the automatic transmission. Most automatics come with a 3.3 final drive ratio and the ring gear is thicker (or thinner, I can't remember) and the diff is built different to allow for this.
You can run any diff you want, but you'll have to switch to the lower gear sets. Most people swapping diffs want a lower gear any way. Maybe go with a nice 3.7 or so.
You might also need different stub axles...
Old Aug 4, 2008 | 01:46 PM
sheplex02's Avatar
i was thinkn bout diff gears too.. and upgraded axles also
Old Aug 4, 2008 | 02:21 PM
_jb's Avatar
_jb
Photographer
Then you can get any kind of diff you want. I have a Carbonetics in my G and really like it.
Here's a link to the Carbonetics diff on Z1 Auto.
http://www.z1auto.com/prodmore.asp?m...ne&prodid=2106
Check out that link and the other diff links on that site. They have a lot of good information in them. If you get serious, give Adam at Z1 Auto a call. He's a good guy and understands these cars inside out.
Old Aug 4, 2008 | 02:30 PM
g35dawson's Avatar
quaife.
Instead of a clutch type differential, it's a Automatic Torque biasing differential. It's a direct drop in for the 5AT's rear diff. It's what I'm saving my money for. Lifetime warranty, and it's supposedly smoother than most of the others. Search for it on here there are some really good reviews.
Old Aug 4, 2008 | 06:19 PM
sheplex02's Avatar
ill be lookn into the Quaife.. and carbon
Old Aug 4, 2008 | 08:25 PM
OCG35's Avatar
Quaife and 3.7 FD here... expensive but very good.
Look into AutoTech’s version of ATB LSD (Quaife units aren’t easily available in the US anymore)... AutoTech is the US rep for Quaife and they are making their own unit similar to Quaife but it addresses the open diff scenario of one wheel in air (research Quaife to know what I'm referencing)
Bottom line - if I was looking right now - I'd be looking at AutoTech's Wavetrack differential and Nissan OEM 3.692 ring and pinion gear set.
happy modding!
Old Aug 4, 2008 | 08:28 PM
sheplex02's Avatar
thank you.. i will
Picture Share
Feb 4, 2018 12:41 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
