best performance N/A upgrades
Old Aug 9, 2008 | 07:44 PM
  #46
cashedg35's Avatar
Originally Posted by Klubbheads
not to be a d*ck but are fvckin blind?
Oh my bad sorry I missed the 4 suggestions amongst 3 FVCKING PAGES OF TALK ABOUT GEARS!!!
Old Aug 10, 2008 | 12:39 AM
  #47
Lolly Baggins's Avatar
you really need to be careful how you talk about me on the forum, i dont appreciate it. tone down the disrespect, i dont know where you're from but where i am from, we dont tolerate that. dont even reply to this, just keep your mouth shut.
consider yourself warned.
(lol jk) :P
Old Aug 10, 2008 | 02:51 AM
  #48
shabarivas's Avatar
he is not joking...
Old Aug 10, 2008 | 03:14 AM
  #49
TIAN's Avatar
Hold The Line
Hey klubbheads I got a 05 G coupe. Stillen intake, ztube, 1/2 spacer, MREV2, HKS exhaust and soon to be Res test pipes. What recommendation do you have gearing wise. I do plan on going boost in the near future if that will calculate in the determination of gears
Old Aug 10, 2008 | 12:47 PM
  #50
If you're going to be getting F/I in the future and you're 100% certain you're going to want 3.3 gears.
If you're not 100% certain, get the 4.083 gears and also make sure to get a tune, especially with your modifications.
Old Aug 10, 2008 | 07:01 PM
  #51
OCG35's Avatar
AT = 3.692 (3.7) final drive gear ratio, anything shorter (3.9, 4.0) is a waste since wee only have 5 speeds.
MT = 3.9 or 4.0...
3.692 and 4.08 are Nissan OEM ring and pinion sets so I would recommend them - they are much cheaper
And yes, shorter FD is a very worthwhile mod! Obviously it doesn’t add power – but will give better acceleration than any bolt on.
Old Aug 10, 2008 | 07:12 PM
  #52
sheplex02's Avatar
ok another question..
the gears make acceleration better.. so does that mean that top speed is reduced?? if so by how much?
cuz ive seen a Z go 183, then 2 weeks later go 204.. and im not lookn to go over 150 alot.. but i wouldnt mind being able to go as fast as possible either..
Old Aug 10, 2008 | 07:29 PM
  #53
OCG35's Avatar
3.3 is much better for top end... if you want to go 150 keep the 3.3 (or 3.5 if you are MT)
If you want zippy street acceleration, quick 1/8 and Ľ mile runs and fast exist speeds out of corners in road racing or auto crossing, shorter gears are the way to go.
I don’t see how there would be a need to go past 100-120 very often – but if so, shorter FD is not for you.
*Edit - this isnt to imply that you are maxed out at 120mph with 3.7, 3.9 or 4.0 gears... the fastest I've taken the G is 140 but that was with 3.3 - I dont know what the top speed without hitting rev limiter is with the shorter gears, but the rpm are about 200-300 higher accross the entire range - 3.9 and 4.0 would be even higher.
Old Aug 10, 2008 | 07:33 PM
  #54
sheplex02's Avatar
as usuall OCG35.. ur awesome.. im probably going to go 3.7 anyways.. so do you know the top speed of 3.7s?
Old Aug 10, 2008 | 07:35 PM
  #55
lekker_droom's Avatar
I am really interested in the final drive now. How will this be for everyday driving though?
Is it going to be noticeable just putting around town and what will it do to gas mileage? Seems like if every shift is resetiing at higher RPM it would burn more gas.
Old Aug 10, 2008 | 08:12 PM
  #56
OCG35's Avatar
I don’t know top speed - haven’t had a chance to get to open secluded road to do a run since the 3.7 - there’s probably some formula to calculate... I imagine 140 is still doable - I'll test it next time I go to high desert.
Old Aug 10, 2008 | 08:22 PM
  #57
OCG35's Avatar
The best thing I can suggest is drive an 07 or newer sedan... it has the same gears 3.692. Its a lot more peppy off the line. For everyday driving its great! It snappier - just better acceleration. And I don’t know why exactly, but the shifts are actually quicker and crisper. I've mentioned it in other reviews - and it’s not my imagination.
mpg does suffer a bit. If you drive a lot and need to keep mpg high, you may not want to swap gears... if you do a lot of fwy driving it might not be too bad... I don’t drive the car every day and when I do its all very spirited driving and mostly street - I get 15-16mpg (don’t let that freak you out though because even with 3.3 daily driven with lots of fwy miles I only got 18mpg.
I almost always run in performance map from Osiris tune - it’s a real aggressive tune... I guess if I used econo mode and drove mellow I'd see better mpg.
Many G have done FD upgrade... I'm not the best example to base mpg on since my driving routine with the G isn’t like most ppl. If you search around you can probably find better and more consistent avg mpg...
Also, for anyone considering upgrading LSD (or in the case of AT just plain adding LSD) you might want to plan to do FD and LSD at the same time since the pumpkin is already open… with the quicker acceleration LSD helps around spirited cornering… VDC isn’t nearly as obtrusive (even when left on)…
Old Aug 10, 2008 | 08:28 PM
  #58
TIAN's Avatar
Hold The Line
How about we open a new thread about this topic instead of cluttering up this thread. Seems very interesting and I dont know much about it.
Old Aug 10, 2008 | 09:03 PM
  #59
OCG35's Avatar
its completely on topic... its one of the best NA mods you can do.
If you’re only interested in engine mods – all the typical stuff that has been mentioned countless of times – intake, exhaust, plenum spacer, high flow cats or test pipes – I have Throttle Body Spacer (which is highly debated, but mostly form ppl that haven’t used this particular design)… if you want to go internals, cams and headers (which are next on my list)… or do a full rebuild. Once complete get a good tune (I prefer Osiris or TechnoSquare and yes I’ve used both).
Isn’t much more than that.
Old Aug 11, 2008 | 09:55 AM
  #60
Shakuya88's Avatar
http://my350z.com/forum/engine-drive...installed.html
This is the info for all gear sets as far as top speed for each gear. AND a lot more info on all gears plus personal reviews. enjoy
