High Pressure Radiator Cap
Old May 5, 2004 | 08:08 PM
DaveO's Avatar
"Keeps higher pressure inside of the cooling system and helps the coolant flow better. It has pressure capacity of 1.3kg/cm2, while the conventional cap has 0.9kg/cm2, this means the coolants boiling point can be raised by use of [this] radiator cap."
Ok, I give. I understand increasing the cooling system's pressure increases the coolant's boiling point and reduces the amount of coolant that overflows to the surge tank... but how does it help the coolant flow better?
DaveO - 2003 G35 Sedan / DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TS ECM / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old May 5, 2004 | 09:50 PM
DED's Avatar
DED
Re: High Pressure Radiator Cap
Higher temp, less dense, easier flow.
But it also means you're overheating for whatever reason.
2004 G35C 6MT Black. Yes Honey, I promise no mods. I love it just the way it is.
Old May 6, 2004 | 03:41 AM
kelven33033's Avatar
can you show me the picture of high pressure radiator cap?
and how do you like our stillen intake
Old May 6, 2004 | 07:41 AM
Meatshackle's Avatar
Deep Sea Moderator
go to performancenissanparts.com
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old May 6, 2004 | 08:49 AM
cato's Avatar
SouthernComfort Moderator
I have this radiator cap. It looks like any other radiator cap,
except it says Nismo on it and has the rating posted as well.
See my 2003 Sedan engine pics. some of my engine bay
pics show it, but not in detail.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Old May 6, 2004 | 09:40 AM
Q45tech's Avatar
Stress on rad, hoses, head gasket!
If you allow the coolant temp to rise above 195-200F you enter the overheat protection mode where ignition advance is pulled out reducing performance.
The last thing you want is a higher pressure cap!
Old May 6, 2004 | 06:16 PM
cato's Avatar
Here is a pic of my Nismo Racing radiator cap.
Old May 6, 2004 | 07:25 PM
DaveO's Avatar
Thanks. I understand the hotter temp = less density theory. But what's the real world difference in pumping effort... seems like a long stretch to me.
If you're looking for a high pressure radiator cap I suggest you check out these links.
http://www.performancenissanparts.co...6f3f5af3e07777
http://z1auto.com/submodel.asp?model=350z&cat=engine
Street Edge TC / B&M Cooler / Stillen Exhaust <P ID="edit"><FONT class="small"><EM>Edited by DaveO on 05/06/04 07:06 PM.</EM></FONT></P>
Old May 6, 2004 | 09:58 PM
DED's Avatar
DED
Difference in density is correct. Higher temp=less dense=lower viscosity=easier flow.
But in the real world, "helps the coolant flow better" seems like a long stretch to me too.
2004 G35C 6MT Black. What Honey? I don't know where they came from. I came home and it was like that...
Old Nov 26, 2019 | 06:53 AM
Austin Bradley's Avatar
2004 infiniti g35 coupe base model
i agree with ya. I had the high pressure nismo cap and my g35 coupe ran hot changed it and now i got air in the system
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
mattdg35
Sep 14, 2015 11:28 AM
twentyeggs
Sep 11, 2015 03:58 PM
