Valve train g35?
Old Aug 20, 2008 | 11:19 AM
specialist's Avatar
Question Valve train g35?
Car: g35 coupe
Year: 2003
I am puting in a twin turbo greddy want to put a little more in the head. just for reforcement. I am going to use stock valve and stock cams.
What is better for my application?
JWT VQ35DE Valve Springs & Shim Kit VS Brian Crower springs / retainer kit
Also can any one explain why ones has shim and one doesn't? yes that a good thing or bad or each?
Also should i get this
Z1 Viton Valve Stem Seals Supposely they are stronger? any buddy use them in their engine build
Old Aug 20, 2008 | 11:28 PM
OCG35's Avatar
why do you need stronger valve springs with stock cam?
Old Aug 20, 2008 | 11:46 PM
Blackbird V35's Avatar
why would you waste the time and money putting any of that stuff in and not change the cams? do you have any idea how hard it is to take the head apart?
Old Aug 21, 2008 | 01:20 AM
Scrooge's Avatar
A shim is use when your valve spring has shrunk. You put the shim between the head and spring to bring back the spring height and tension. So you mostly on use shims engine's with some wear.
Old Aug 21, 2008 | 02:25 PM
specialist's Avatar
i am ripping out the engine and it is going to be taken apart reason is b/c i have major tick noises in head. Would you just recomend change just the shims? should the spring and shim kit fix my ticking?
Old Aug 21, 2008 | 04:10 PM
GreenGoblin's Avatar
The goblin resurrection
I suggest ig you are messing with the heads get some cams while you are in there
Old Aug 21, 2008 | 05:56 PM
are you sure its in the head? knock travels very well through an engine.
Old Aug 22, 2008 | 02:12 PM
specialist's Avatar
i am getting the bottom end done too
Old Aug 22, 2008 | 02:13 PM
specialist's Avatar
i am worried about cams tho. what one would you suggest then with a turbo setup
Old Aug 23, 2008 | 02:18 AM
Scrooge's Avatar
If your going to put new shims. Making sure you use the right thickness to bring the spring back to spec.
Old Aug 23, 2008 | 02:34 AM
ttrank's Avatar
Grocery getter
I drove my 04 sedan (same exact motor) with a Greddy TT for a year before building the motor for more power.
If you are going to take off the heads just get new cams and do a valve job. But if you are going that far just build the bottom end too.
Old Aug 25, 2008 | 11:17 PM
all depends on what your goals are.
alot of people use the brian crower stage 2s
I personally run the GTM turbo cams and have no problems
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
lemmy999
Jul 25, 2015 12:13 PM
laksjd84
Jul 24, 2015 05:12 PM
Ashton35
Jul 17, 2015 10:11 AM
