I "FIXED" my oil consumption on the v2
Old Sep 25, 2008 | 12:18 PM
Gdonz35's Avatar
Originally Posted by EncoreCestMoi
I do not want to go through another longblock replacement and I want to go boost. I am not dropping coin on that until I am sure the engine is tight and ready for it.
i feel the same way
Old Sep 25, 2008 | 06:23 PM
AustinG35's Avatar
Originally Posted by geronimomoe
All I can say is this:
1) Vary the speed of your car as much as possible.
2) Downshift (with double clutching) as you approach every traffic light to slow down.
3) Follow the break-in procedure Nissan specifies.
1) +1 as long as you keep it below 4000 rpms during your break-in period.
2) "Double clutching"? Who are you, Vin Diesel? (Sorry, couldn't help myself...) Seriously, you don't need to double clutch your car, you have a synchronized transmission (as with pretty much ALL cars nowadays) and dropping your gears to reduce your speed only increases engine/transmission wear because you putting an unnecessary load on the engine. You should only do this if you are speeding and your radar goes off at night and you need to brake relatively quickly, and don't want the cop to see you brake. lol.
It's much easier and less expensive to replace brake pads as opposed to replacing your clutch/transmission.
3) Not 100% certain, but I believe per the Nissan manual, for your G35, you should be driving varying speeds but keep your RPMs below 4000 for the first 1200 miles.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
