Want to upgrade my Engine. Help pls.
Old Sep 16, 2008 | 05:01 PM
Doidera00's Avatar
i'm currently running 253 Wheel HP on my 05 g35 coupe 6mt. i don't want to do a turbo or anything for now. I just want naturally aspirated. What can i do to the internals of my engine to get me some hp already getting it started to handle a turbo. so far on the inside of my engine i have done nothing. I want to get on the 300hp or so for now. What upgrade can i do that will give me plenty or power and wont cost that much. pls any sugestions. If so what and what brand. i want to built my engine first before putting a turbo.
Old Sep 16, 2008 | 05:49 PM
tecni's Avatar
well its counterproductive if you wanna up N/A power but at the same time prepare it for boost since an NA motor thrives on high compression and a boosted car typically needs to have way lower compression to avoid detonation. You need to make up your mind. You should be looking at a fuel return system with an upgraded fuel pump, exhaust, forget an intake system since a turbo kit will change all that and just focus on buying pistons, rods, bearings, studs, etc... and eventually get it all put it.
Old Sep 18, 2008 | 02:42 AM
DEMoLITIoN's Avatar
Stroke it!!
Old Sep 18, 2008 | 02:45 AM
DEMoLITIoN's Avatar
big bore + short stroke = HP
These engines can handle turbo pretty good. Do as tecni says, just buy light.
KruZZe
Feb 27, 2023 05:04 PM
hrdwirk1
Oct 2, 2015 06:34 PM
NyCrAzY
Oct 1, 2015 09:19 AM
