engine power loss when sound system on High
Old Sep 21, 2008 | 05:53 PM
maciejk's Avatar
hi, does anybody get this, when their sound system is on high volume above 24, i notice power loss, car hesistates, why is that so? does the sound system take the amps off the spark plugs or something like that? i have a stock BOSE system
Old Sep 21, 2008 | 06:08 PM
Naveed2126's Avatar
Could be that your alternator isn't able to charge the battery quick enough when the amp draws all that power. Just curious, do you have an aftermarket sound system installed, if so, what's the RMS power rating on the amp?
I have a JL 10W7 hooked up to a JL 500/1 amp, and even that I have connected to a Rockford Fosgate cap and when a big note hits, I notice the needle in the speedometer jumps up a little bit.
Old Sep 21, 2008 | 06:15 PM
maciejk's Avatar
hmm i should've mentioned i have a stock BOSE system
Old Sep 21, 2008 | 06:44 PM
5150DS's Avatar
If you have the stock battery, make sure the water levels are not low. Not sure if this is the problem, but can't hurt.
Old Sep 22, 2008 | 05:23 PM
ttrank's Avatar
Grocery getter
The stereo may not be the problem at all. It may just be that your battery is going out and the alternator is pushing all it can just to power the motor and charge the battery a little.
Old Sep 22, 2008 | 05:41 PM
maciejk's Avatar
i think i have a one year old battery in there i'm not sure, but isn't the battery just for starting the car, dosen't the alternator take care of everything once the car is running?
Old Sep 23, 2008 | 08:24 AM
Q45tech's Avatar
If the alternator is functioning properly and all 3 sections are creating equal current [3 phase system]..............common for alternators to overheat and lose [blow open] a diode and 33% of capacity disappears............then overtax the other 2 causing total failure soon after...............applies to all brands of alternators generically = how they fail.
A properly functioning battery is necessary to smooth the alternator output otherwise you get ripples in waveform and whines in sound system.
mjfenix
Aug 17, 2017 05:49 AM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Frostbite91
Aug 2, 2015 04:59 PM
BlackGee35
Jul 21, 2015 07:24 PM
