ATTN: Drag Racers
Old May 24, 2004 | 12:01 PM
KAHBOOM's Avatar
Re: ATTN: Drag Racers
gurgen you da man... much knowledge!
2003.5 5AT
Premium Package
Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old May 24, 2004 | 02:31 PM
GurgenPB's Avatar
Thanks guys... yes, it is very useful for that purpose as well -- but don't forget, you do not have VDC/ABS when the switch is open, so be careful while running in "stealth mode". Actually, the funny thing is, that I didn't realize this benefit of the switch until afterwards, I did it to deactivate the brake LSD feature.
Gurgen
Old May 24, 2004 | 07:30 PM
gspot35's Avatar
Gurgen,
Do you get the slip/VDC/brake light all on at the same time when you flip the switch? It won't go off for me until I reboot the ecu....key off, then on.
03 Sedan ~ 5AT ~ aero ~ 19x8" Axis wheels ~ Garnet ~ premium ~ NISMO body kit ~ clear front corners ~ Stillen Cat-back ~ Injen CAI ~ Crawford plenum soon (shipped!)
[image]c:\sig.jpg[/image]
Old May 25, 2004 | 12:02 AM
GurgenPB's Avatar
Yep , exactly,
you have to restart your car
Gurgen
Old May 25, 2004 | 02:07 AM
RavenR's Avatar
OK... conclusion is what? VDC off = not good for launches? this is some confusing stuff...
Ivory Pearl Coupe/5AT/Aeros/Premium/Nav/Type-N Front Bumper/Z-Tube+Popcharger/V1
Old May 25, 2004 | 02:22 PM
GurgenPB's Avatar
VDC is good for launches, brakeLSD is good for launches, niether is good for maneuering as you are much more likely to lose control
Old Aug 3, 2004 | 06:28 PM
bosssho's Avatar
Gurgen...I have one of these too, but I don't think it restores the 30% at all and I also still feel like I am bogging some times if I brake torque off the line...
I am still reading through this post, but PM me if you would
like to discuss more, b/c I know I would. Thanks.
EDIT:
I just read the whole post and I am now more confused...is VDC, IYHO, better or worse for our cars to launch at the drag strip...which is all I am concerned with of course. ;-)
IMHO, my best launches have come from little to no wheel spin and a 1500 RPM launch...I am hoping that with the Nitto Drag Radials I will be able to brake torque more, but only if I know I am not losing 30% of the power to VDC/ABS or what ever the Christ the Nissan donkey put into our cars to rob us of all the power. (Did you see my recent post on what the new Corvette can do with VDC???)
John
03.5 G35 5AT 14.2 @ 96.4
10 Wire Grnd Kit K&N CAI w/Injen HS UR UD CP
Coupe Mid Pipe CrawfordV5.0 TS 350Z 170F Stat
02 Maxima SE 4AT 14.5 @ 95
87 Mustang GT 13.2 @ 107<P ID="edit"><FONT class="small"><EM>Edited by bosssho on 08/03/04 03:41 PM.</EM></FONT></P>
Old Aug 3, 2004 | 06:56 PM
neffster's Avatar
So for fleeing and eluding police there's only one solution where you can run in stealth mode and have every available hp hit the ground.
<hr></blockquote>
This is good stuff! LOL... BTW, I've dragged the G 4 or 5 different days (maybe 10-20 runs) and have "accidentally" left my 2004.5 6MT VDC on. My times all sucked with the VDC on. Taking it off helped tremendously. (Just adding more merit to gurgen's comments, as if they needed any merrit).
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Old Aug 4, 2004 | 02:00 AM
GurgenPB's Avatar
OK, i prolly confused the snot out of a lot of people. I think I meant "VDC off is good for launches". Brake LSD, in theory is supposed to help you launch more uniformly, like an LSD would. It's BS imo, as it accomplished this (i.e. stability) at the expense of overall power you put down to the ground.
I haven't used this switch in a long time. When I get a scanner i will do a test to see if the timing is in fact pulled by the ECU without the brake fuse vs. with the brake fuse. But given how busy I am with the rest of the car, make sure to bug me about it so that i do not forget.
If you want to discuss this more, PM me or smth (or leave your phone number and i will call you sometime if you have any more questions).
Gurgen
Old Aug 4, 2004 | 11:35 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
g35noob,
wheel hop is NEVER good. It's bad for the launch and terrible for your back axle.
2 G or NOT 2 G, there is no question!
Injen SES, Kinetix cats, K&N Typhoon, 19" PIAA Super Rozza's (19x9 & 19x10)
Old Aug 4, 2004 | 11:37 AM
n3m's Avatar
n3m
<hr></blockquote>
So... if that's true, what if instead of an ON/OFF switch, you made a momentary switch to briefly open the circuit. This way the system will completely deactivate VDC/TCS/ABS until you restart your car. But since it's momentary, your brake lights will still work?
If you have the switch, maybe you can test this by flipping the switch closed after VDC/TCS/ABS have been disabled, and then test to see if your brake lights now work. It'd be interesting, and good solution for those of us that want the ease of truely 'switching' the safety systems off (instead of going through the hood fuse), but don't want to sacrifice the brake lights.
AJC128
Nov 1, 2015 11:55 AM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
edwinisdumb15
SOCAL Meetings & Events
Sep 18, 2015 06:46 PM
twentyeggs
Sep 11, 2015 03:58 PM
