"You need to replace your engine"
Originally Posted by Texasscout
I have found that once you "over heat" an aluminum block motor the damage is done. You warped something (head most likely) and there is a small leak in a head gasket. It's possable that the heads could be removed, decked and the head gaskets replaced. You might get by with that and if it works trade that sucker in ASAP!
you could get the motor up and running by just having the heads trued and
a valve job done if needed....new gasket and you're back on the road. Like
Texasscout mentioned trade it in while no one's looking....LOL
Gary
Strange. Why does it take a week or two to overheat? Are you checking the radiator fluid level regularly?
Clearly you are losing coolant and it takes a week for it to loose enough to overheat the motor. You should really be checking it and NOT waiting until it overheats everytime.
You probably have a coolant leak from a slightly blown headgasket.
The dealer should be peforming a leak down and a compression check vs just guessing. Hell I could guess better than that.
I agree with jeff, this is complete horsesh1t. I had a lexus that had the same problem and it was a blown headgasket. I got it fixed for 1200 bucks and was a noob and probably got ripped off a bit.
Thanks but we are not going the fi route. I was thinking along the lines of bang-for-the-buck mods (cams, tb, etc.).
Unless you are going to go FI, go stock. Of course, you are saving the money of a tear down just to build it if you do it now. It may add 2000-3000 to your build.
First you need to find out if the car is actually over heating. The temp guage sensor might be bad, giving u false readings. Nissan uses two temp sensors, one for the ECU and one for the gauge in the car.
If the car is over heating (boiling coolant), then it is loosing coolant probably thru the engine. Did you notice any white smoke? exhaust smells like syrup?
I would put in some stop leak and trade it in asap.
A temp sensor wouldn't cause an overheat. A stock thermostat might.
Again a leakdown test/compression test is in order here.
Did you check the fluid level each time it overheated?
Normal better than average educated technicans would do a hydrocarbon leakage test- measuring if any combustion gases are leaking into coolant.
http://www.troubleshooters.com/toverheat.htm
Sorry about the picture cannot delete it from link?????
http://www.freepatentsonline.com/4102178.html
That's what ticked me off about the service dept at the dealer.
The day we dropped the car off at an independent mechanic, he called to tell us that he did a pressure test and saw coolant leaking from the passenger side head.
What did he know that the service dept at the dealership didn't?
A pressure test is very different from a test to see if combustion gases are present in coolant.
Either way a cracked/failed head effectively proves serious owner abuse in allowing an overheat.
The rub with not using dealer on new models is the serious redesigns the V6 got in 2002 and the every year subsequent redesigns to fix problems.
As an independent group of 3 shops [15 techs] who speciliaze in just Infiniti and Nissan we have a difficult time keeping up. Can you imagine what the average work on anything shop has to suffer.
We buy over $1 million per year in Infiniti parts from a single dealer so you can be assured we get our questions answered fully.
After any vehicle is 6 years old the technology is pretty well understood by those that specialized in the brand but be careful and be sure to quiz the technican before allowing him to trash or learn on your vehicle.
