Have squeaking noises at cold starts before and after belt changes..
Old Jan 27, 2009 | 12:42 PM
  #46
g35freak86's Avatar
mine has actually subsided. I went under the car once more to see if I could tighten it up and if there was anything else I could do to fix it. Once the weather dried up and did a bit more tightening, it seemed to have stop. I'll get a little random squeel (quiet) at a light or something, but other than that, it's good. I may just have them changed at my next service though.
Old Jan 28, 2009 | 08:23 PM
  #47
hai00's Avatar
My 05 started making sqeak at 40k. I've been thinking of changing it too.
If you guys want to change the belts, the link below may be helpful.
http://forums.nicoclub.com/zerothread/349821
Old Feb 12, 2009 | 05:20 PM
  #48
g35freak86's Avatar
Welp, finally sucked it up and went to the stealership to have it looked at. The squeel was getting out of hand and even more embarrasing. Ended up having to replace the pulleys and both belts and all is well. It was a pretty pricey bill, but I did get other things done. Just happy that crap is gone and I can drive the car without fearing red lights and parking lots
Old Feb 12, 2009 | 06:00 PM
  #49
04G35NYC's Avatar
^ PM me please how much and what pulleys you replaced thanks.
Old Feb 12, 2009 | 06:13 PM
  #50
g35freak86's Avatar
PM'd ya man
Old May 5, 2009 | 08:21 PM
  #51
leeroydstroy's Avatar
^ can u please pm me too with how much this cost u and which pulleys were replaced? Thx man much appreciated.
Old May 5, 2009 | 08:31 PM
  #52
g35freak86's Avatar
pm'd ya
Old May 6, 2009 | 05:40 PM
  #53
dnice7914's Avatar
pm me too please
Old May 6, 2009 | 05:59 PM
  #54
WILLIE BEANS's Avatar
just remembered my mechanic brushed the pulleys and cleaned them off ..
on an old buick regal i had .. made the squealing go away ..
try cleaning the pulleys..
or check if its coming from alternator or other ..
see pic ..
pic is from a d.i.y. someone posted on nico forums here ..
Old May 9, 2009 | 03:25 PM
  #55
BH818's Avatar
I read the whole forum, I have the same problem on my 06 G35 with 29K miles. I changed blets already tighening it I already did. It happens during COLD start might be the bearing.
WHAT EVERY U DO DONT SPRAY WD-40 OR ANY TYPE OF OIL! MAKES IT WORST!
Old May 9, 2009 | 03:44 PM
  #56
BH818's Avatar
Anyone change there pulleys? Does it help? or is it a bearing problem for sure? cuz my uncle is a mechanic and he suprised after changing belt it still make noise
Old May 9, 2009 | 04:31 PM
  #57
g35freak86's Avatar
Last thing you want to do is put ANY pil on the belts. Any oil on the belts makes the belts squeel.
It cost me around 400-500 (with labor) to replace all pulleys and belts back in February and everything is still good. haven't heard a peep out of the belts/pulleys since then. It was the first time the belts were changed for 60k. The pulleys were worn and needed to be changed as well. I still hear a bit of that "metal ball bearing" sound around 3k rpms once in a while, but goes away after engine warms up
Old May 9, 2009 | 07:04 PM
  #58
BH818's Avatar
well I dont think its the pulley then. Its the bearing. Its either the P/S, I/P, Alt or C/P bearing
Old May 9, 2009 | 10:49 PM
  #59
g35freak86's Avatar
^ that is what could maybe be causing the "metal ball bearing" sound. But replacing the pulleys and belts got rid of the squeeling, which was my main concern.
Old May 9, 2009 | 10:53 PM
  #60
BH818's Avatar
did you get OEM pulley of aftermark ones? Because the after market ones was very light and the weight on the bearing might be doing it
