Have squeaking noises at cold starts before and after belt changes..
#78
idler pully
this is the idler pulley or the belts. either one or both. i have a 2006 G35 sedan 6mt with 10K miles on it. no bad weather or anything. i got the noise about one year ago. had it take to the dealer and the report said that the idler pulley (did not state which one) was worn and replaced.
noise came back 5 months later and they replaced the belts. both time noise was gone. it is back..so i think that the other pulley is gone. now i have to see which one. also could be loose belt. i will check. not as bad this time. but if it is a horrendous noise i bet it is the pulley bearing. the dealer said that they were bad.
thanks
john
p.s. all was warrenteed
thanks
john
#79
thanks
john
thanks
john
#82
im having a problem with a loud noise during cold starts i only hear it when im driving and my car isnt fully warmed up . i replaced my belts a few monthes ago with oem nissan ones.as soon as my car is fully warmed up the noise goes away . i kinda think its comming from the intake but i have no idea
#85
I have pretty much the exact problem as the op. Got my belts replaced, and my car squeals horribly after I start it up if it has been sitting for a few hours. Goes away after 10-15 seconds. I've read the entire thread, and there seems to be no consensus on the problem. I really don't want to spend a bunch of money at the stealership, but I have no clue what the problem is. This has been going on for months now, and I'm ready to get it fixed.
#86
#87
#88
Aftermarket belts, especially quality ones, wont cause issues. Its all about proper tension. If its squeaking check out your idler pullies. Remove belts and spin the pullies. If operation is not smooth but you hear internal grinding in the pulley the bearing is bad.
If idler pullies are good then you just need to tighten the belts a little more. Do not over tighten or you will cause issues...
#89
