Oil change advice?
Old Nov 3, 2008 | 06:51 PM
Driver99's Avatar
Oil change advice?
I have a '08 G35 sedan and am coming up on my 3rd oil change at 11,250 miles. The first 2 changes were done by the dealer for free and now I'm on my own. I was thinking of going to synthetic oil and doing it myself. Can anyone tell me if its difficult to, first do the oil changes and second... what brand of oil is good. I also wanted to know if I should stick w/ the OEM oil filters or go w/ aftermarket. So far I've decided to go w/ the Valvoline SynPower oil and a K&N oil filter...any comments would be appreciated.
Old Nov 5, 2008 | 04:00 PM
Luv2xcelR8's Avatar
Any name brand oil filter will be fine. An example that seems to be popular is amsoil. I am planning on switching to synthetic soon but from what I have heard valvoline, penzoil, mobil 1, etc. are all great oils. Changing the oil should not be hard either. Check out some online videos for a DIY. Hope that helps some..
Old Nov 5, 2008 | 04:03 PM
WhosRich's Avatar
search is ur friend
Old Nov 6, 2008 | 03:16 PM
GreenGoblin's Avatar
The goblin resurrection
I would also get one of the Fumoto valves that are forsale right now
Old Nov 8, 2008 | 04:43 AM
Andrei's Avatar
Mobil 1 5w30 and full bottle of Lucas synthetic oil stabilizer.
Old Nov 8, 2008 | 05:09 AM
Og_Dave's Avatar
i like redline , and ya oil change is easy and fun man.
just jack up the car , take off the under skid pad, unscrew the drain plug, let it drain and put on your new filter, then fill with 5qt of oil and your done man!
Old Dec 1, 2008 | 12:22 PM
Swivel's Avatar
Moderator
Easy DIY and good to know it's done right. Amsoil 5W-30 and Wix or Amsoil filter is all I use.
Old Dec 14, 2008 | 06:39 AM
340WHPG35's Avatar
Make sure to pre-fill the oil filter first! Esp. turbo'd apps.
Old Dec 18, 2008 | 02:47 PM
SwanyJr's Avatar
I just had mine changed. I put Valvoline Full Synthetic in it, and my car seems to love it. Synthetic is definately the ONLY way to go. It is a lot better for your motor, etc. If you end up going synthetic, don't switch back and forth.
Old Dec 18, 2008 | 02:49 PM
SwanyJr's Avatar
What does the Lucas do for the synthetic oil? Is it a must have or just another thing.
Old Dec 18, 2008 | 03:12 PM
Swivel's Avatar
Moderator
Takes several dollars out of your pocket.
http://www.bobistheoilguy.com/images/lucas/lucas.htm
Draw your own conclusions.
Old Dec 19, 2008 | 10:59 AM
2008G35XSinMD's Avatar
+1
DO NOT USE LUCAS.
Search the net for more interesting information regarding Lucas.
Old Dec 19, 2008 | 11:16 AM
PAIXAO's Avatar
Holy Crap! I would have never guessed. I've personally never added any additives to my oil and never would, but that's just interesting.
Old Dec 19, 2008 | 02:38 PM
SwanyJr's Avatar
WOW! Keep that crap away from my engine! Who ever said to add that should probably change their oil....now.
Old Dec 21, 2008 | 11:19 PM
STILLENRedline's Avatar
Its clearly stated that no oilwith additives
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
