Create an OBD Trouble Code?
Old May 26, 2004 | 11:43 AM
god_of_cpu's Avatar
StreetDeck.com Developer
I just finished writing an OBD II reader program for the ELM chip and I now need to test the Mode 3 and 4 functions for it that query and reset trouble codes.
Anyone know of an easy way to create a trouble code in the g35 so I can test reading and resetting the trouble codes?
Preferably something easy to do that won't actually break anything in the car.
Old May 26, 2004 | 11:52 AM
redwillow's Avatar
20 Year Member
Re: Create an OBD Trouble Code?
disconnect the MAF sensor plug will do the trick.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, double 15% tint
Old May 26, 2004 | 12:15 PM
DaveO's Avatar
god_of_cpu,
ELM = ?
If you want an easy way to bring in one or more DTCs, disconnect your MAF Sensor and start the engine. Immediately stop the engine and reconnect the sensor. Re-start the engine and you should see the SES light.
Your ECM should be at least one DTC. Most likely you'll also have a 1st trip DTC, Freeze Frame Data, 1st trip Freeze Frame Data. I don't think this will bring in a 2nd trip... or "Two Trip Detection Logic" code. Hopefully you will have the STR code.
Good luck.
DaveO
2003 G35 AT Sedan / DP / Willow / Premium / Sport
350Z T-Stat, Engine Cvr & Air Duct / Stillen CAI / Crawford Plenum
GG 10-Wire Kit / TS ECM / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old May 26, 2004 | 12:33 PM
god_of_cpu's Avatar
Thanks, I'll try to disconnect the MAF once I go home.
The ELM is a chip that is used to interpret OBD II data directly from the OBD II BUS and turn it into a more convienent ASCII format capable of being read by PC serial ports.
See this thread for more info on the chip and how to create a circuit. http://www.mp3car.com/vbulletin/show...734#post200734
You can also purchase the circuit at www.scantool.net
Old May 26, 2004 | 05:24 PM
DED's Avatar
DED
Leave the gas cap loose?
2004 G35C 6MT Black. I stare. And I am content.
Old May 27, 2004 | 10:18 AM
cato's Avatar
SouthernComfort Moderator
That is what I was gonna suggest. I just had my SES light
come on because I left the gas cap attached to the door
instead of on the gas tank. Our Gs will sense this and throw
on the Service Engine Soon light. It will take a few drive cycles
for it to be detected.
2003 TwBlue 5AT Sedan, sunroof,
Graphite Leather, splashguards, HKS exhaust,
14 wire Grounding kit, 350Z duct, Stillen CAI
Underbody rear diffusers, Drilled alum pedals
Freeman186
Sep 6, 2023 10:07 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
vamarris
Sep 26, 2015 12:56 PM
