Idle pulley delete w/ DM2 spacer
Old Aug 9, 2009 | 09:40 PM
vq35dedriver's Avatar
any noticeable gains?? or was this strictly for looks (cleaner look)??
Old Aug 9, 2009 | 10:04 PM
Boston's Avatar
^ not going to gain but you will reduce weight and clean up the engine bay.
Old Aug 10, 2009 | 12:08 AM
Tollboothwilley's Avatar
Whats the spacer for ??
Old Aug 10, 2009 | 11:25 AM
Andrei's Avatar
Actually believe it or not I did notice a difference in throttle response after I did this on this car.
Old Aug 10, 2009 | 02:28 PM
whats the reason for the spacer...and where can I get one?
Old Aug 10, 2009 | 02:31 PM
Andrei's Avatar
Originally Posted by GreenGoblin
hey buddy, glad to see you got around to doing this.... The spacers are machined to exact tolerances there is no need to shave it down, you may need to loosen the ps bracket to wiggle it in there. Other wise it is a tight fit, cant wait to see it finished
GreenGoblin sells them. But you can just order an aluminum pipe and cut yourself one. The spacer goes in between the timing cover and power steering bracket. I didn't use it.
Old Aug 10, 2009 | 02:45 PM
Jeff92se's Avatar
Red Card Crew
Nice pics and thanks for the belt p/ns. But a ratchet shouldn't be used with a breaker bar like that.
Old Aug 10, 2009 | 03:16 PM
Andrei's Avatar
It's the only way to get the bolts loose. You can try and air racket but it doesn't have enough torque and you cant fit an air gun in there.
If you are doing this make sure you don't strip the bolts from the tension pulleys. They are smaller and they are tight too so they are easier to strip.
Old Aug 10, 2009 | 03:22 PM
Jeff92se's Avatar
Red Card Crew
Breaker bar with the 3/8" or 1/2" drive should be used vs a ratchet. The bar extension is hard on the ratchet mechanism and could break it.
Old Oct 15, 2009 | 04:24 PM
ttrank's Avatar
Grocery getter
Next mod on my list after the diff cooler.
Old Oct 19, 2009 | 02:44 PM
Andrei's Avatar
It's definitely improves the look of the engine bay with a lot less clutter in there. If you have a smaller crank pulley you need a different belt. I do not know the part number though. The DM2 people know it.
Old Oct 20, 2009 | 12:03 PM
How much is the DM2 spacer?? and where can I get one?
Old Oct 21, 2009 | 03:22 PM
Andrei's Avatar
Ask greengoblin for one. I am not using one though.
Old Oct 21, 2009 | 03:38 PM
GreenGoblin's Avatar
The goblin resurrection
Andrei you really need to put in the spacer, if you keep running the belts with tension on them and no spacer or idler you can cause potencial damage to the treads in the block where the bracket bolts up. If you are having trouble getting the spacer in crack loose the 2 bolts that go through the bracket in the block to give you more wiggle room.
Old Oct 23, 2009 | 12:54 PM
  #30
Green...
what do you charge for the spacer?
