Purlator PureOne oil filter...
Old Dec 1, 2008 | 12:10 PM
Swivel's Avatar
Moderator
Originally Posted by OCG35
I use it or Napa (made by Wix) exclusively.
I use the Wix also, p/n 51365 or you can use the larger (Maxima) one which is p/n 51356. I think I will actually upgrade to the Amsoil EA012 next oil change.
Old Feb 2, 2009 | 05:50 PM
dohturdima's Avatar
Amazon has 2 Purolator PureOne PL14612 filters for $9.48 + freeship
Old Feb 3, 2009 | 04:06 PM
G35fromPA's Avatar
Regarding the OEM filters, as I recall, both the 65 and 9E (larger) filters are made with metal endcaps. Someone cut them open & posted pics a few years back on this forum. So, they should be fine, espevially if you are doing regular oil/filter changes.
Old Feb 8, 2009 | 01:41 PM
Mustang5L5's Avatar
Originally Posted by MidnightG35X
PL14610 for the extended, bigger than stock size.
PL14612 for the stock size.
I recommend the PL14610, bigger is better
I saw both in the store and picked up the 612 for now. I did notice the 610 was a little longer. It can be used with no negative effects I assume?? No clearance issues or fitament issues?
Old Feb 8, 2009 | 01:54 PM
superchargedg's Avatar
It will work fine.
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
