spark plug question
Old Nov 28, 2008 | 11:49 PM
4drmadness's Avatar
spark plug question
hey guys i have 64k on my car. getting very close to ending my powertrain warranty. Ive heard a bunch of people having leaking valve covers. i have a 04, so im concerened. Do you guys think i should check for the oil leak first, and get it fixed, and then change the spark plugs, or change the spark plugs and then get it fixed if i have this problem.
Old Nov 29, 2008 | 12:11 AM
Texasscout's Avatar
Do you smell oil burning? If not, your VC are most likely not leaking. I also thought that plug changes were at 100,000 miles. I'll have to check.
Old Nov 29, 2008 | 12:27 AM
kmckis1029's Avatar
what years have the oil leak problem?
Old Nov 29, 2008 | 12:29 AM
4drmadness's Avatar
03-04
Old Nov 30, 2008 | 11:23 PM
kegels's Avatar
Yep, I have an 03 w/ 107K miles and I changed the plugs today only to discover that the valve covers are leaking(both sides). Pool of oil inside the plug well.
Old Nov 30, 2008 | 11:41 PM
4drmadness's Avatar
damn, i gotta check this before i hit 70k
Old Nov 30, 2008 | 11:47 PM
Shakuya88's Avatar
I smell oil sometimes. usually just after getting up to highway speeds and it's very faint. Do you think this problem is starting to show itself in my car? It's an 04
Old Dec 1, 2008 | 03:06 PM
ttrank's Avatar
Grocery getter
Oil smell could be as simple as your car burning a little blow by oil.
Old Dec 1, 2008 | 04:13 PM
Texasscout's Avatar
Yes, most likely you have a very small valve cover leak that runs down to the exhaust header and smokes. It's unlikely that it will be coming from the exhaust directly as the cats burn up most any oil smoke until they are so contaminated, they can't "light off" anymore.
Or, it could be some grease monkey spilled some oil on your motor last time you had your oil changed.
Old Dec 1, 2008 | 08:02 PM
RADIOGUY21's Avatar
do the 05-06s have this problem?
Old Dec 1, 2008 | 08:03 PM
4drmadness's Avatar
nope. you are good to go
Old Dec 1, 2008 | 11:29 PM
RADIOGUY21's Avatar
sorry to threadjack but they actually made a change for this problem for the 05+? A valve cover change?
Old Dec 2, 2008 | 12:14 AM
Shakuya88's Avatar
I'll check the sides of the motor tomorrow morning to see if there is any oil on there. If there is something there, would it be just a new gasket or is it more involved?
Old Dec 2, 2008 | 07:22 AM
Texasscout's Avatar
You should be able to smell it when you open the hood right after your car come up to running temp.
Old Dec 3, 2008 | 06:52 PM
bythabay's Avatar
Yes, all first generation G35 models both coupe and sedan are affected.
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
mtlruss
Dec 20, 2015 01:51 PM
yosip1115
Aug 20, 2015 10:30 PM
JoeMac
Aug 20, 2015 10:17 AM
yassy
Aug 9, 2015 07:31 PM
