fluid change at 70000
Old Nov 27, 2008 | 09:52 AM
filthyg35's Avatar
hey guys, I have an 04 ip coupe coming up on 70000 miles and have never had the trans flush or differential...the car has been great to me and have never had (knock on wood) any problems with the car except for the usual wear and tear items. I have read conflicting stories wether or not to get the tranny flushed at such high mileage...some say do it and some say it may "shock" the tranny and make it fail sooner...any advice would be appreciated..thanks
Old Nov 27, 2008 | 10:00 AM
JZ39's Avatar
Just do a quick drain and fill on the tranny. No need to flush.
The diff. you can have drain and filled as well easily.
Old Nov 27, 2008 | 10:38 AM
Sponger's Avatar
6MT Brembo Coupe
You didn't specify which tranny you have -- MT or AT. The MT can be easily drained and filled. If you have the AT, the pan and torque converter should be drained. The torque converter holds quite a bit of fluid so if you only drain the pan, you'll be mixing new fluid with a lot of old.
Old Nov 27, 2008 | 02:48 PM
filthyg35's Avatar
yeah I guess AT or MT might help...I have an AT....so it wont be a problem to have it totally flushed at 70000 for the first time?? like I was saying a few threads I have read said that a total flush at such a hile mileage may compromise the tranny or was that for MT?? I'm still confused...I will start searching again...
Old Dec 3, 2008 | 07:08 PM
bythabay's Avatar
why didn't you service the trans and differential at 30k intervals as recommended in the owner's manual?
Hawk196
Sep 22, 2015 02:51 PM
Eomfd
Aug 29, 2015 12:42 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
linedr89
Aug 17, 2015 05:11 PM
NemesisGee
Aug 11, 2015 07:10 PM
