+15HP ?
Old Jun 9, 2004 | 12:58 AM
mikeb2004's Avatar
+15HP ?
Anyone know exactly what they did to the 2005 6mt coupes to get +15HP? If not, then any educated guesses?
Old Jun 9, 2004 | 03:12 AM
havok5414's Avatar
Re: +15HP ?
Probably put in the a less restrictive intake like the Z tube or something and maybe tinkered with the ECU maps a little but. I dunno and that's just my guess.
Inside my shell, I wait and bleed
2003.5 Black/Black 5AT Fully Loaded w/ Navi
Clear Corners / Injen CAI
Old Jun 9, 2004 | 08:10 AM
SixFive's Avatar
Re: +15HP ?
I'm sure that will be analyzed as soon as the first guy comes on here and says he bought a new 05...i cant wait
2003.5 DP 5AT Sedan (E-thing but Nav)
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Jun 9, 2004 | 09:13 AM
zimbo's Avatar
Re: +15HP ?
I'm just hoping that they didn't get the +15HP by advancing the timing. That would suck for people who want to go with forced induction.
--Steve
Old Jun 9, 2004 | 07:59 PM
EverythingG35's Avatar
Re: +15HP ?
I'm anxiously awaiting the new parts CD's with the 05 models so I can see the part differences between the 03-04 and 05 models. I'm hoping it's something mechanical, rather than electrical.
Justin @
EverythingG35.com
1.888.216.5328
Old Jun 10, 2004 | 08:21 AM
SixFive's Avatar
Re: +15HP ?
My nickel's on:
1) Revised Plenum - possibly only thing they change ECU Nothwithstanding - time to break away from the Z a bit
2) or ECU/timing modifications only.
I doubt exhaust will change much and the intake rocks now apparently; 2-3 hp is not worth add'l noise a an entry-lux car should have.
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Jun 10, 2004 | 09:26 AM
Airs414's Avatar
Re: +15HP ?
does anyone know when the specs of the 05's are coming out?
Jump and the net will appear
Old Jun 10, 2004 | 03:50 PM
Tfasano's Avatar
Re: +15HP ?
My guess would be that they watched the aftermarket and took notice of the hot buttons...Plenum and Ztube being the most obvious.
Luv My G
Old Jun 10, 2004 | 04:27 PM
Sinurgy's Avatar
Re: +15HP ?
That would be sweet if it was a revised Plenum. Then those of us who haven't went Crawford or Kinetix could just put on the new Infiniti Plenum!
R.I.P. Pat Tillman 1976 - 2004
Old Jun 11, 2004 | 01:15 AM
deadmanincbh's Avatar
Re: +15HP ?
I would not be supried if its a port and polished headers, and higher power polished intake.
Old Jun 11, 2004 | 07:46 PM
duckygirl's Avatar
Re: +15HP ?
wrong?
Old Jun 12, 2004 | 01:28 AM
nuttyprof's Avatar
Re: +15HP ?
ECU. they've revised the ECU every year almost.
G35s6mt/TSecu/350Z Springs&Struts/K&Nfilter+Z-tube/StillenDualExhaust /6WireGroundKit/KinetixHighFlow
Old Jun 12, 2004 | 03:23 AM
kwakman's Avatar
Re: +15HP ?
The ECU alone won't make 15 horses off of our cars imo. I think that the Z-tube and a newly designed plenum and some small tweaking to the ecu(for the additional air) would be most likely. But we'll never. =P
'03 G35c DG/G 6mt, full options
Mr_pharmD
Engine - Intake/Fuel
Mar 5, 2011 02:03 PM
nmanti
Apr 19, 2008 04:04 PM
DOCSG35
Nov 29, 2007 12:29 PM
