CF Engine Cover Rubbing Air Inlet Duct
Old Jun 9, 2004 | 09:17 AM
bzabodyn's Avatar
My new 350Z carbon fiber engine cover is rubbing the front air duct that funnels air to the intake - what should I do? Does anyone else with this engine cover have the same problem?
Also - (off topic) Does anyone know how to remove super glue? It was the only thing I could find to attach my Infiniti logo off of my old engine cover to the new one and it left a residue in a few places - I just don't want to mess it up worse using something I shouldn't to remove it...
2003.5 Brillant Silver G35 coupe 5AT
JDM Clear Corners, Alum. Pedals, Pro-1 Short Ram Intake, Helix SS Test Pipes, UR Crank Pulley, Custom Grounding Kit, CF Engine Cover, Kinetix Plenum (On Order)
Old Jun 9, 2004 | 02:00 PM
TCFOOL's Avatar
Re: CF Engine Cover Rubbing Air Inlet Duct
I have that same setup... Mine only really rubs in one small area.. I used a small piece of thin foam tape.. worked great and barely noticeable. As far as the super glue removal... humm can't help you there..maybe try Goof Off..
TC
"There is a Very Fine Line Between "Hobby and Mental Illness"
Old Jun 9, 2004 | 02:12 PM
BigRon's Avatar
Yeh, Goo-B-Gone or something similar might work. You know who will know for sure? The Superglue manufacturer's help/questions/hotline. Just be sure to tell them what it's on and if it's clear-coated so they can suggest something that might not damage your cf engine cover.
On another note: If you find something that removes the superglue really well, you might thing about stripping that emblem off and re-attaching it with some of the double-sided 3M body tape that's used to attach body/aero pieces. That Superglue is known to get brittle when it gets hot. Don't want that emblem falling off while you're driving.
'05 IP(or ?) 6MT... ...Never too soon to think about modifications!!
jsimonk
Dec 22, 2023 03:49 PM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
derres
Aug 28, 2015 03:27 PM
joedaddy1
Jul 28, 2015 02:58 PM
Kz_Ed
Jul 23, 2015 02:41 AM
