K&N hp-1006 oil filter - can I use it on my G35
Old Jan 29, 2009 | 02:44 PM
Smokey6's Avatar
Hey guys,
I ended up buying 4 K&N hp-1006 oil filters. According to the K&N site, the recommended oil filter is 1008. I'm not sure how I screwed this one up, but I did. I think I remember reading that the 1008 is just an oversized 1006 - it certainly screwed onto my oil tank okay (ie. no leaking).
Is there any harm in me using this 1006 filter on my car?
Thanks in advance.
Old Jan 29, 2009 | 02:46 PM
Jeff92se's Avatar
Red Card Crew
If that 1008 fits the VQ35 powered maxima, you're probably okay. I use the Napa Gold filter that's spec'd for the maxima because it's a tad larger.
Old Jan 29, 2009 | 02:51 PM
Swivel's Avatar
Moderator
Looks like it's meant for Kia/Mazda 626/Ford Probe. 1008 is the right one. Maybe you can make a trade?
Not sure what to tell you on that besides if it were me, I wouldn't let 10 bucks stand in the way of putting the right filter on my car.
Old Jan 29, 2009 | 06:33 PM
Smokey6's Avatar
agreed - I already bought a new hp-1008. Shoot...Just wish I hadn't bought 4 of them when I got them!
Old Jan 29, 2009 | 06:42 PM
Swivel's Avatar
Moderator
Hit the mazda forums or put 'em on kijiji or something.
Old Jan 29, 2009 | 06:47 PM
Jeff92se's Avatar
Red Card Crew
Uh has receipt? can returns?
Old Feb 8, 2009 | 04:58 PM
CLIFF's Avatar
I use the largest filter that will fit my G. In my case I have found that the filters fitting the Nissan V8s, Titan and Armada have the same base plate as the Nissan/Infiniti 3.5L V6s. They have a larger capicity and cause no interference with anything under the engine. The thimble under the G just barely qualifies as a filter IMHO. Bigger is BETTER!!!
Old Feb 10, 2009 | 02:56 PM
ttrank's Avatar
Grocery getter
I use the 110's on my car because they are larger. They are listed for the FX. I believe the 106 is smaller. If so, stay away from those.
Old Feb 10, 2009 | 04:28 PM
Sacch's Avatar
why is bigger better in this case?
Old Feb 10, 2009 | 05:12 PM
Canadian's Avatar
Canada, eh?
I use the Titan filter too because it is bigger. I do not know why it is better, I just know it is recommended.
To the OP, if it fits the VQ (and is the same size, or bigger) a filter is a filter, no? I don't see why it wouldn't work.
Old Feb 10, 2009 | 05:24 PM
Jeff92se's Avatar
Red Card Crew
I bit more filter area to have before it gets clogged up. we are probably not even coming close to that anyway but that's the common reason.
Old Feb 10, 2009 | 05:49 PM
ttrank's Avatar
Grocery getter
More area to filter and more volume to keep it clean. Maybe just for peace of mind but that's my $0.02.
Old Feb 10, 2009 | 07:51 PM
PTownG's Avatar
I always use the HP-1010. Same fitment as the HP-1008 but about 30% more capacity. It's what the M45 uses.
Old Feb 11, 2009 | 07:29 AM
fast04G's Avatar
what about keeping the oil pressure throughout the filter? Just a thought...
Old Feb 11, 2009 | 04:40 PM
ckg35's Avatar
+ on the HP-1010
