Torque Wrench Suggestions
Old Jun 16, 2004 | 10:35 AM
shibal_z's Avatar
Looking to buy some tools to work on my G. A friend suggested getting a torque wrench to help me with oil changes. Wondering if any of the gear heads here can give me some advice on getting one. What torque rating wrench should I purchase? Any good brands? Good places to buy? I'm also looking for a filter wrench attachment, but hard to find the size that fits our OEM filters.
Thanks!
<font color=red>Shibal G-Thang</font color=red>
<font color=blue>'04 TB 6MT Graphite: Aero Pkg, Premium</font color=blue>
Old Jun 16, 2004 | 11:30 AM
3point5SE_Auto's Avatar
Re: Torque Wrench Suggestions
0-80 foot lb is a good starting torque wrench. Buy quality, craftsman at a minimum, snap on is better. Enjoy
down the road you may want to invest in a 0-250 ft lb torque wrench as well and possibly a inch lb (small) torque wrench.
I use my 0-80 for just about everything, my 0-250 for suspension parts and lugs, and my little torque wrench (0-30 inch lbs ) for nothing really.
Your oil filter should only be on hand tight, after the first oil change you shouldn't need a filter wrench. The suggested way to install a oil filter is to lube the o ring with new oil, then thread it on until it is flush. then turn it 1/4 to 1/2 turn past that point. As long as it is on a new car it shouldn't leak like this. Mine neve have
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Old Jun 16, 2004 | 11:47 AM
al503's Avatar
I don't really think you'll need a torque wrench to change the oil. Good advice from 3.5SE.
I got a 50-250 snap on and it's great. I use it for suspension pieces and torquing the lugs. (I'll have 3 sets of wheels pretty soon so it'll save me a lot of $)
Whatever one you get either for oil changes or changing wheels, make sure that you get it calibrated on a yearly basis more or less, which will depend on how much you use it.
Old Jun 16, 2004 | 05:43 PM
DHCrocks's Avatar
I've got a MAC that goes from 50 to 250 ft-lbs, it has a plastic/rubberized cushion handle. that thing is great no fatigue on your hands, it's especially helpful when torquing to high specs since your hand doesn't get sore. I highlly recommend that you get one with a comfort grip. Although this range is not very usefull, I would recommend one that goes from 20 to 100 ft-lbs, a much more usefull range and it will be smaller so you can get into tight locations better.
Old Jun 17, 2004 | 11:01 AM
KingoftheRoad1's Avatar
As for the oil filter wrench, get a metal flexible one so it will auto grab the filter tight when you remove it. As suggested earlier, don't use the wrench for tightening.
2004 G35X
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Rose M
Oct 12, 2015 10:00 AM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
