HELP PLEASE!!! blown fan and water pump pulley!!!
Old Feb 22, 2009 | 12:57 AM
Tollboothwilley's Avatar
I actually have my fan clutch and fan blade...from when I did the E-fan conversion.
www.infinitipartsonline.com
fan shroud is about $70 for both parts new
fan is about $75
fan clutch is $112
The pulley you would reuse...and maybe the fan clutch depending on the condition
Old Feb 22, 2009 | 01:00 AM
str3zz's Avatar
Originally Posted by Lucky-G
Definitely DO NOT drive the car this way. If it's warm in your area the car will most likely overheat when sitting at a stop.
What ***** is saying is that you probably snapped off the bolts inside the block.
I'm not going to drive it. I'm scare to just even turning on the car.
I just look at the bolts again and it doesn't seem to be snapped off it more like off from something since I found couple of metal bearings that seem to be holding that bolts ro rotate when the belts rotating the pulley.
Old Feb 22, 2009 | 01:01 AM
Lucky-G's Avatar
Did you really notice any gains when you did the E-Fan? Cooler water temps, response, etc.?
Old Feb 22, 2009 | 01:05 AM
str3zz's Avatar
fan is about $75
fan clutch is $112
I still need that fan pulley for holding on the belts even I do the conversion am I right?? Where can I buy the damn fan pulley.
Thanks for the info I'm cheking it out right now
R u selling your old fan by any chance?
Old Feb 22, 2009 | 01:12 AM
reuse the pulley that you have....
your problem is the bolt attached to the engine block that holds that pulley on
Old Feb 22, 2009 | 01:13 AM
I might sell my fan/clutch/shroud if the price is right
Old Feb 22, 2009 | 01:14 AM
str3zz's Avatar
from the infinitipatsonline.com i found this
http://www.infinitipartsonline.com/p...layCatalogid=0
number 6 on that picture indicating pulley bracket. that's the one that holding the bolts that was off from mine isn;t it??
Old Feb 22, 2009 | 01:16 AM
Lucky-G's Avatar
Do us a favor. Call your local infiniti dealership. Have them tow it. And have THEM fix it.
Better yet. Have them buy your car and ride the bus. WTF Man...are you drunk? Comprehend what the man is telling you!
Old Feb 22, 2009 | 01:37 AM
str3zz's Avatar
LOL. I wasn't drunk. I just like to explore stuff. Modification that i did by my self on the car 5 1/6 Morordyne copper iso spacer, AEM intake, r34 front end bumper, side skirts and rear bumper, earth grounding, trans flush, oil change, rear differential oil change, and some other interior stuff dvd and such.
For that being said, my a/c belts split into two, solution fix it so i can drive it to work. find diy in here and try to save money since economy is bad but then again i forgot to buy belts tighten measurement like the video diy have so i just taking my chances by listening to it (since someone else wrote diy and mention that) but i guess not really have a good hearing .
Old Feb 22, 2009 | 01:43 AM
str3zz's Avatar
That pulley brackets from infinitipartsonline.com seem came with that bolt. I just doulbe check again, that bracket is exactly like i have and only 3 bolts are actually holding on to it. in the back of that bracket is just engine block and not even attached to it except for that 3 bolts of course. I put my finger to the hole and hit the engine block and also the gap from the top could see there is nothing else behind the bracket. I hope i'm right.
I'm going to give infinitipartsonline a call on monday regarding the pulley bracket if it come with bolt to hold on to the pulley it self.
how much are you willing to sell the parts? I think the clutch are still good all i need is the fan blade and upper + lower shroud.
Old Feb 22, 2009 | 01:46 AM
str3zz's Avatar
hmm i just found something not sure what it is but there is a liquid dripping from the shroud. i checked all the hoses and none being cut from that fan.
Definitely need to check the radiator.
Old Feb 22, 2009 | 01:54 AM
Lucky-G's Avatar
That's definitely no good. I would guess your radiator is fu<ked. Time for a Koyo.
Old Feb 22, 2009 | 01:57 AM
str3zz's Avatar
I don't see any radiator hoses being cut or anything. I just have to double check on that.
Old Feb 22, 2009 | 02:00 AM
Jeff92se's Avatar
Red Card Crew
fan is about $75
fan clutch is $112
Hey! You write a thread about the conversion? let me know what you did for fans and the electrics!
To the OP, you could always just leave the fan off (I'd leave the bracket as it serves as a spacer for the power steering pump)
You just need a belt that's 1" shorter. Dig though my posts, there was an article detailing this mod from Quadcam
Old Feb 22, 2009 | 02:03 AM
  #30
str3zz's Avatar
For some reason I like you. Now we are talking. I will look into that or if you have a link to make it easier to find please do so.
Thanks
