HELP PLEASE!!! blown fan and water pump pulley!!!
Old Feb 22, 2009 | 02:05 AM
  #31
Lucky-G's Avatar
No fan? He lives in AZ lol
  #32
Jeff92se's Avatar
Red Card Crew
https://g35driver.com/forums/engine-...-mod-pics.html
But remember, quadcam doesn't have the clutch fan, his newer car has electric fans. But the pulley stayed for some reason
Old Feb 22, 2009 | 02:21 AM
  #33
str3zz's Avatar
E-fan might be good idea at this point but since my big o radiator gasket is cut from the fan crashed so I guess $365 for the whole radiator assambly and no conversion keep it stock since wife is yelling behind me seing the price to fix keep going up lol
Old Feb 22, 2009 | 02:35 AM
  #34
str3zz's Avatar
Yes finally found a good pictures of that fan pulley bracket. I was right it's not attached to the engine block. That bolt came with the bracket and have 4 screw to attached the fan clutch.
List to buy: pulley bracket, fan blades, radiator assembly and that's should be it $$$$$$
Old Feb 22, 2009 | 09:19 PM
  #35
Carlito's Avatar
I had a similar problem, not caused by tightness of the fan, but by damage to the bracket caused by the previous owner. The fan came forward into the radiator and cut abouy 4 of the tubes. I had to get a new radiator and a new bracket. Fortunately the fan survived.
In your case, I suspect your coolant is coming from the radiator too. Koyo time.
Old Feb 22, 2009 | 10:44 PM
  #36
str3zz's Avatar
Who have your radiator fix? Did you have to purchase the whole radiator kit or just the part that is broken? if you did it your self can you show me the right direction where can find the diy for it?
thanks.
Old Mar 24, 2012 | 05:05 PM
  #37
jcronkhite's Avatar
Hey guys. How do I replace the water pump. is it behind the inspection plate or do i have to pull the whole timing chain cover
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Learned Hand
Oct 1, 2015 09:02 AM
Hogbone
Sep 28, 2015 06:44 PM
