question
Old Feb 23, 2009 | 11:40 PM
thatsmyG35's Avatar
question
I have looked everywhere and cant find an answer. Im sorry for asking a newbie question but what is rev up and how do you know if your G has it? thanks.
Old Feb 23, 2009 | 11:47 PM
O HELLA OEM's Avatar
i think revups are for 05-06 G35 6mt coupes
someone correct me if im wrong
Old Feb 23, 2009 | 11:48 PM
AVATAR77's Avatar
Without getting into details, it's got more HP (but less torque) than then non-Rev up engine and redline is 600 RPM higher on Rev Ups. For sedans, Rev Ups are on the 05-06 6MTs only, so it wouldn't be on your '04.
Old Feb 23, 2009 | 11:51 PM
thatsmyG35's Avatar
So would getting the motordyne MREV 2 along with a motordyne plenum spacer be pointless?
Old Feb 23, 2009 | 11:53 PM
jack_burton's Avatar
just get the spacer
Old Feb 23, 2009 | 11:56 PM
thatsmyG35's Avatar
thought so.
Old Feb 24, 2009 | 12:18 AM
coup de grace's Avatar
It's not pointless, you just don't see the same kind of gains from the MREV2 as rev-up engines do.
Old Feb 24, 2009 | 12:26 AM
thatsmyG35's Avatar
would it be worth it? would the gains be similar?
Old Feb 24, 2009 | 12:29 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
the gains are similar if you get a tune afterwards. But i wouldnt recommend getting a tune until you have all or most of your mods done. EI: Exhaust, High Flow Cats or Test Pipes, Intake, MREV2, spacer, headers (if you opt for headers)
-GP-
Old Feb 25, 2009 | 12:57 AM
ttrank's Avatar
Grocery getter
Did you read the sticky since you started this thread in the 03-06 sedan section?
https://g35driver.com/forums/g35-sed...edan-faqs.html
Post #3
Q - What is the REVUP, and do I have it?
The REVUP engine is included in 05/06 6MT (manual) sedans. The REVUP engine redlines at 7000 rpms, versus the standard redline of 6600. The REVUP includes variable timing on the exhaust cams in addition to the intake cams, as well as different timing/fuel maps in the ECU.
Old Feb 25, 2009 | 01:08 AM
thatsmyG35's Avatar
Post #3
no, sorry i did not. I used the search which i remember being told to use and it was very unhelpful. I didnt notice the sticky.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
