kinetic velocity manifold..is it worth it?
Old Feb 27, 2009 | 04:14 AM
sammy_G's Avatar
Originally Posted by Blackmouf
And the Nobel prize for best research goes to.........
Great write-up! You never seem to fail me. You're becoming on of those Mr. G35driver guys that I look up to.
i think he just copy and pasted
http://www.uucmotorwerks.com/html_pr...torquemyth.htm
Old Feb 27, 2009 | 10:29 AM
07PEARL6MT's Avatar
Originally Posted by sammy_G
and like I said I would have a good flow on my car. You can do whatever you want with yours.
Old Feb 27, 2009 | 11:05 AM
xXHotelCrazyXx's Avatar
Its easy to google what ever you are looking for. You will find the answer almost 99.99999% of the time. I was way to lazy to type up a whole explanation when someone else has done it for me
Old Feb 27, 2009 | 01:51 PM
07PEARL6MT's Avatar
now if only teachers would have that same mentality
Old Feb 27, 2009 | 02:42 PM
Im sure there are plenty of them that do.
Old Feb 27, 2009 | 03:23 PM
07PEARL6MT's Avatar
I meant as far as turning in work.
Old Mar 2, 2009 | 12:32 AM
rcdash's Avatar
In regards to the topic of this thread: No. Do a little searching on Kinetix - few people will continue to have faith in their products after their last fiasco. Those that remember or know how to search anyway.
In terms of exhaust "back pressure", the excerpt above fails to talk about scavenging and velocity, 2 key components of exhaust design. Don't believe everything you read on the Internet. That said, turbos and back pressure are a no no and yes you can potentially increase torque by reducing exhaust pipe diameter, and no it is not from an engine burning leaner or richer! LOL. Closed loop O2 feedback has been around for over a decade!!!
Old Mar 2, 2009 | 12:37 AM
SDGeneralCounsel's Avatar
Some say that "an engine needs backpressure to work correctly." Is this true?
No. It would be more correct to say, "a perfectly stock engine that cannot adjust its fuel delivery needs backpressure to work correctly." This idea is a myth. As with all myths, however, there is a hint of fact with this one. Particularly, some people equate backpressure with torque, and others fear that too little backpressure will lead to valve burning.
The first reason why people say "backpressure is good" is because they believe that increased backpressure by itself will increase torque, particularly with a stock exhaust manifold. Granted, some stock manifolds act somewhat like performance headers at low RPM, but these manifolds will exhibit poor performance at higher RPM. This, however does not automatically lead to the conclusion that backpressure produces more torque. The increase in torque is not due to backpressure, but to the effects of changes in fuel/air mixture, which will be described in more detail below.
The other reason why people say "backpressure is good" is because they hear that cars (or motorcycles) that have had performance exhaust work done to them would then go on to burn exhaust valves. Now, it is true that such valve burning has occurred as a result of the exhaust mods, but it isn't due merely to a lack of backpressure.
The internal combustion engine is a complex, dynamic collection of different systems working together to convert the stored power in gasoline into mechanical energy to push a car down the road. Anytime one of these systems are modified, that mod will also indirectly affect the other systems, as well.
Now, valve burning occurs as a result of a very lean-burning engine. In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating.
Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust because of the way that backpressure caused air to flow backwards through the carburetor after the air already got loaded down with fuel, and caused the air to receive a second load of fuel. While a bad design, it was nonetheless used in a lot of vehicles. Once these vehicles received performance mods that reduced backpressure, they no longer had that double-loading effect, and then tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque.
Modern BMWs don't have to worry about the effects described above, because the DME (car's computer) that controls the engine will detect that the engine is burning leaner than before, and will adjust fuel injection to compensate. So, in effect, reducing backpressure really does two good things: The engine can use work otherwise spent pushing exhaust gas out the tailpipe to propel the car forward, and the engine breathes better. Of course, the DME's ability to adjust fuel injection is limited by the physical parameters of the injection system (such as injector maximum flow rate and fuel system pressure), but with exhaust backpressure reduction, these limits won't be reached.
For one, the correct term is not backpressure. Back pressure is never good for any car. What the determinate factor is velocity
Old Mar 2, 2009 | 02:16 AM
Velocity and pressure are directly related Now back to the drawing board. What are you trying to prove again?
Visionnn
Oct 3, 2015 05:16 AM
leo38cheng
Sep 29, 2015 05:43 PM
