Valve ticking
Old Mar 3, 2009 | 07:59 PM
OCG35's Avatar
Originally Posted by xXHotelCrazyXx
I had already bought a can of it, thats why i posted a thread about it. I already used it on my Toyota pickup and had no problems doing so.How are you going to tell me i havent used it yet? Did you come over to my house and walk into my garage and see a full can of unused seafoam? Why the fvck do you all of a sudden care so much about what I am doing? Fvcking troll.
why would you post a thread asking about the stuff if you've already used it - genius.
Old Mar 3, 2009 | 08:00 PM
Jeff92se's Avatar
Red Card Crew
fight! fight!
xXHotelCrazyXx's Avatar
Originally Posted by OCG35
just because you post bad info in threads that I was already subscribed to (and get email notifications on) doesn’t mean I take time "too see what you're up to"... I couldn’t care less about what you are up to.
I have never posted any bad info. I wouldnt do that to another member. Im a very active member on here to share my own personal experience and info with others. Just because i said Nismo cams and Cosworth are the best, you squeeled like a little fvcking pig and got all bent out of shape over it. So i dont have the same taste as you is no reason to go around saying "i post bad info" Ive got nothing but thanks, thanks for your info, it really helped me out, or your advice helped me fix my problem. I would never post any info if i wasnt 100% sure about it. You have no idea who I am or what my experience of mechanics consist of. To sit there because you cant stand the fact that i have a different point of view than you and say i post false info is BOGUS. You need to grow the fvck up and deal with the fact that others minds dont function exactly the way your simple mind does
Old Mar 3, 2009 | 08:08 PM
G35 Mass's Avatar
I'm a good chunk over 100k. Jesus Christ my house-saving budget can't afford a 1,000k car bill....
Old Mar 3, 2009 | 08:09 PM
OCG35's Avatar
Originally Posted by Jeff92se
fight! fight!
he's just getting frustrated because I keep calling him on things like asking about a product in one thread - and then recommending it in another thread 6 hours later... or because he tells people if they have cams and full exhaust they will reach 300+ hp... or that nismo and cosworth cams are the only ones to consider... or that oil vapor blow by is needed to lubricate "upper cylinders"... and now that valve tick is normal (without even hearing the OPs car) - excessive valve tick is not normal and can definitely be a sign that lash is loose - but without hearing it and isolating it, how can you diagnose it?
The guy is going to steer a lot of people the wrong way.
Old Mar 3, 2009 | 08:10 PM
OCG35's Avatar
valve job would be at least that much...
Old Mar 3, 2009 | 08:32 PM
Your a goddamn liar.
1) I had already bought the product, then used it. Then reccomended it to G35 Mass. So i dont know what tandem your going off of.
2) 300 hp is def obtainable with full exhaust and a tune with cams. Big deal if I prefer coswroth or nismo, its no reason for you to get your panties in a wad over it because its not what you have.
3) I never said blow by is needed for upper cyl lubricant We can let the readers find out what a douche you are and your failed attempts to make me look bad. Your just making **** up in hopes people will go straight to the end of this thread and read your post.
Old Mar 3, 2009 | 08:42 PM
Try the seafoam. Pour about 1/3 of a bottle in your crank case. It will quiet lifter noise if thats what it is. I adjusted the valves once i did the head on my truck and i had a little tapping. I need to drive it atleast 500 miles before i do the second adjustment but for now the seafoam has quieted the rocker noise.
Old Mar 3, 2009 | 11:01 PM
OCG35's Avatar
https://g35driver.com/forums/engine-...does-work.html
then read post # 2 in this thread (note the date and time of each post)
https://g35driver.com/forums/tuner-d...o-results.html
your crazy comment starts on post #6 – this isn’t even the thread that you instead nismo or Cosworth are the only cams to consider – that one is here:
https://g35driver.com/forums/engine-...some-info.html (post # 2)
3) I never said blow by is needed for upper cyl lubricant .
https://g35driver.com/forums/engine-...nder-wall.html (post #15)
I think they will figure it out from your posts... I've done some of the legwork to make it easy
and to top it all off - here's a great post of yours:
I have an SSV intake manifold, so no cover for me!
that was determined yrs ago to loose power for NA (boatloads of threads about it and I’ve seen it twice on dynos when Kinetix first came out with it) - FI has seen small hit & miss gains though... I'm pretty sure you arent FI.
Old Mar 3, 2009 | 11:06 PM
Damn all that research and you still havent proved anything. Quoting everything ive said within the past few days and you still call bs I can do the same the and quote you as well and call BS. Doesnt mean it is, but if i feel like pulling **** out of my *** I could say the same thing about you and also how you throw a fit if you dont get your daily reach around. Your the only one on here thats so upset about my difference in opinion. Because its not shared or viewed by yours, your painties are so far up your t w a t. You said you wernt going to argue anymore. Are you not a man of your word? Do you need a band-aid for that cut between your legs Once again, your the ONLY one who seems to think otherwise. Im still here, we can go in circles all day long
Old Mar 3, 2009 | 11:17 PM
OCG35's Avatar
^^^ I called you on your BS again... and you're having a temper tantrum again
Old Mar 3, 2009 | 11:19 PM
^^^ I called you on your BS again... and you're having a tempoer tantrum again
Temper tantrum? That is me trying to redeem myself from laughing so hard. Honestly, i was laughing so hard, i literally had to step out side because i was sweating! Pay attention and look around, your the ONLY onewho thinks other wise. Thanks for the laugh, keep it coming! What else do you got for me!:bo wroflbowroflbowroflbowroflbowrofl: I have all night! Its my weekend BTW!
Old Mar 4, 2009 | 12:05 PM
Q45tech's Avatar
Luckily there is nothing in SeaFoam that can cause damage [unlike some other oil additives]................pale light oil, rubbing isopropyl alcohol, and naptha........mostly light oil.
The semisolid lifters use 24 shims to set lash so a proper method is to measure lash and measure shims both hot and cols and select new shims from the ~ 50 different sizes to make up for cam, valve seat, or valve stem head wear.
Normally one just learns to ignore the wear and noise.
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
TNRocker
Sep 21, 2015 08:36 AM
