HELP...blinker is blinking really fast
Old Jun 28, 2004 | 05:07 PM
MyGUnit's Avatar
my passenger blinker blinks very fast when i turn it on....what is the reason for thisand how do i fix it?...my drivers side blinker is fine
thanks for the help...
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old Jun 28, 2004 | 05:09 PM
waijai's Avatar
i.love.gold
Re: HELP...blinker is blinking really fast
check to see if your filament is out in the turn signal bulb....most cars blink fast as a sign the bulb is burnt out
Old Jun 28, 2004 | 05:18 PM
Raznips's Avatar
what moog said... i havent had one go out on my g, but i used to drive a suburban and my right blinker went out twice and it would start blinking insanly fast. Turn on ur blinker and get out and actually look at it (front and rear)
2004 Black on Black g coupe 6spd.... <3 aluminum pedals, clear corners, z tube, and pop charger. From down south, houston tejas
Old Jun 28, 2004 | 05:27 PM
G35Rush's Avatar
my brothers 325ci has been doing that recently too, he said the bulb blew out and just hasnt had the time yet to replace it
i would recommend replacing it if it really bothers you
Jeff - Look for me in the black G
2004.5 G35 Coupe
5AT / Black on Black / Premium / Splash
Old Jun 29, 2004 | 06:38 AM
MyGUnit's Avatar
i thought it would be that too, but all my bulbs are working fine...
maybe if i disconnected my battery it would reset it, cause i recently disconnected my headlights?
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Clear Corners
Pop Charger
Z-Tube
Old Jun 29, 2004 | 11:36 AM
BigRon's Avatar
Maybe, but have someone watch to make sure ALL of your rear bulbs are good on that side. If they are, grab replacement bulbs and stick them in your glove box. One of the bulbs is about to go. Just had this happen on another car of mine. Started flashing fast but bulb must have been working internittently still. Totally burned out within a day or two.
'05 IP(or ?) 6MT... ...Never too soon to think about modifications!!
Old Jun 29, 2004 | 02:10 PM
GRider35c's Avatar
they blink faster not because it was designed like this, but because its the laws of physics (electricity that is)... if you put a smaller wattage bulb, or no bulb at all, it will blink faster... i intentionally did this on my old toyota!
04/BO/G/aero/splash/prem/perf/cc/22%tint
Old Jun 29, 2004 | 02:12 PM
jjellyneck's Avatar
Everyone is probably correct about the bulb.
I do know that if you've added more current draw or load on the circuit, it'll also blink faster. My experience is that if you wire a car for a trailer and plug in the trailer lights, the signals will blink faster. If that happens with a trailer, then I go to NAPA and get a heavy duty flasher module for a few bucks $ and plug it in. There's a slim chance that something similar is going on.
'04 6MT coupe
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
magnetism80
Jan 27, 2016 12:57 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
