Low dyno question
Old Mar 25, 2009 | 12:36 AM
llut5at's Avatar
Low dyno question
So last month I put my car on a dynojet dyno in fairly cool conditions and came up with a rather lean A/F ratio of 14.0 and low numbers Max HP was 194.2 HP Max TQ was 181.8 lb/ft this is SAE correction. The dyno graph was also I really bumpy, especially compared to others. I figure my car is just a factory fluke seeing as I have seen other sedans put down just as much HP as coupes and there were other G's there that day dynoing from 220-245 N/A with similar mods as mine. Just wondering if I can chalk it up to my car being a factory fluke or if something is wrong.
I've got a 2004 5AT G35 Sedan with a Stillen intake, z tube, MD 5/16" Spacer, and a HKS Muffler
any ideas?
Thanks
Travis
Old Mar 25, 2009 | 02:03 AM
Canadian's Avatar
Canada, eh?
Your A/F was 14 all the way across the run?? Dude, you need to get that looked at or your mods are causing you to run way too lean. You need a tune
Old Mar 25, 2009 | 02:11 AM
llut5at's Avatar
it was like 13.7 from 3600 to 4500 then it was 14 to 14.15 from about 4500 to 5300 then it dropped down steadily till redline at 6200 where it was about 13.4. would a tune fix that? or should i just deal with low numbers till I can afford to go FI and then tune it.
Old Mar 25, 2009 | 09:29 AM
djamps's Avatar
Those numbers are really low.
Old Mar 25, 2009 | 11:04 AM
llut5at's Avatar
tell me about it ><
Old Mar 25, 2009 | 01:50 PM
str8dum1's Avatar
i wouldnt even think about FI until you had the motor checked out. assuming that the dyno was correct, your motor might be on its last leg. i'd do compression and leak down
Old Mar 25, 2009 | 08:04 PM
Canadian's Avatar
Canada, eh?
^+1 you should get it checked out man
Old Mar 25, 2009 | 08:07 PM
llut5at's Avatar
should I take it to a tuning shop or the stealership to have them look at it, i get the car in for routine maintenance ever 3,000 miles or so and the dealer didn't say anything but i didn't ask
Old Mar 25, 2009 | 08:13 PM
godmans's Avatar
take off ur CAI then redyno
Old Mar 26, 2009 | 12:22 AM
llut5at's Avatar
you really think its that serious?
Old Mar 26, 2009 | 07:27 AM
str8dum1's Avatar
go to a different dyno and retest. if it is still that low, there is something wrong with your motor. thats honda civic power.
Old Mar 26, 2009 | 08:24 AM
on3_Lo35's Avatar
don't feel bad I got a 04 5at I got 198 whp stock... I added exhaust, MD 5/16th spacer and hks duals, plugged upRev to it and played with the a/f ratio to about 13.5:1 all the way across the board, and play with a lil timing in the upper RPM I'd say about 5800-6600, I made 213whp after that....I gotta get back on the dyno n play with upRev some more
Old Mar 27, 2009 | 10:11 AM
llut5at's Avatar
anyone know if a building the motor would fix a compression issue if there is one?
Old Mar 27, 2009 | 11:13 AM
Hydrazine's Avatar
Yes. A built motor should at least have the bore inspected along with new rings installed.
jsimonk
Dec 22, 2023 03:49 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
