Manumatic Mode
Old Apr 8, 2009 | 07:34 AM
OBG3506's Avatar
^^ sorry brothers, i will keep yall in my prayers!
Old Apr 18, 2009 | 12:21 AM
steadygrinder87's Avatar
why does every time i shift from D to Manumatic mode, while i'm parked it goes to 4M., when someone i know who has a 350Z and when he shifts from D to manumatic mode while parked it goes to 1M?
Old Apr 18, 2009 | 12:27 AM
Blue Meanie's Avatar
Mine goes to 4, no matter what speed I'm doing, even if it doesn't actually go to 4th. It's weird. I'm interested in ther VB purely for crisper shifts.
Old Apr 18, 2009 | 12:51 AM
NaiveRapture's Avatar
That must be a year specific thing... Mine shifts into whatever gear it thinks I should be in at that current speed. Weird thing is though, if I'm doing 80 on the freeway and switch to Triptronic, it goes to 4th, not 5th. Not entirely sure the reasoning for this.
Old Apr 18, 2009 | 07:39 AM
That's what I mean. If I am sat at the light, and switch to MM, it reads as 4th. If i'm at 80, and switch to MM is shows 4th.
Old Apr 18, 2009 | 08:19 AM
Vrod-Mike's Avatar
If I'm standing still and I shift to MM it goes to 1, but if I'm on the highway it will go to 4.
Old Apr 18, 2009 | 08:20 AM
SIR NUPE A LOT's Avatar
I get the same thing...always switched to 4m....and usually at the speed I'm driving it should be in 3rd.
Old Apr 18, 2009 | 09:56 AM
STCLAIRWEST's Avatar
I think it switches to 4 on the high way for you 04.5 and up so when you switch it to hit higher rpms to switch lanes and pick up more speed.
Old Apr 18, 2009 | 12:04 PM
DaveB's Avatar
Search people. All this has been covered in hundreds of previous threads.
Old Apr 18, 2009 | 12:33 PM
04ScoupeAT's Avatar
i could be wrong but usually the last gear is Final drive ratio gear....so if u were goin for top speed run u would use 5th otherwise ur fine in 4th...i really only shift into 5th when im at 80 to keep RPM's low.....maybe a 6MT owner can chime in.....do u need to use 6th gear or is it more or less a "habit" and cant u keep all ur useable power in 5th and not need 6th? OR am i way out in left field and its needed lol
Old Apr 18, 2009 | 03:40 PM
Oh God... The 'search-bores' have arrived.
Old Apr 20, 2009 | 05:43 PM
Nope... The search bores are the ones that come in, riding a high horse, proclaiming "have you not used search" and then gallop off after being no help to whoever. I think they were born condescending. The thread started at point A, and went to point B, then C and so on. People adding to the conversation as it went, and so on, and so forth. I'm sure you have added to a conversation that has actually been mentioned before. hell, I'm sure everyhting has been covered many times. Might as well close down the forum and call it a FAQ.
Old Apr 21, 2009 | 11:22 AM
  #30
04ScoupeAT's Avatar
WELL SAID....id even say that last sentence is SIG material
