g37 oil analysis
Old Apr 1, 2009 | 01:05 AM
IrockAG35's Avatar
Ohio G Club moderator
Originally Posted by w0ady
i dont get worked up over the net.
the point is to show the decrease in foreign matter as the engine breaks in and confirm that things drop to normal levels.
i also blew my g35 motor @ 68k miles due to oil consumption. they said it was due to "excessive downshifting". the crazy thing is i drive an auto which is super rare to have oil issues. just trying to keep a better eye on things with the new car.
interesting to know..sorry for thread bashing 1st post
Old Apr 6, 2009 | 05:08 PM
w0ady's Avatar
fgc moderator
Originally Posted by orl-g
oooh these samples were still when you were running oem for break-in.
doh!
yeah post motul samples later if possible.
ya i plan on doing the next change for sure. its pretty neat, i might even do a few more.
no worries.
Old Jun 18, 2009 | 06:06 PM
w0ady's Avatar
fgc moderator
latest oil change @ ~10k miles (~5k interval):
oil is actually 5w40 if i remember right. only negative so far seems to be higher aluminum but like they said, it could just be the longer interval. also, i just came back from zdayz so i was pushing the car pretty hard up there. interested in seeing how the next aluminum reading comes back unless i end up at an auto-x or something. also did the tbn this time to check life and 5k is definitely ok, i could in fact go longer but i doubt i will.
Old Jun 25, 2009 | 10:32 PM
njchen24's Avatar
Thank you for sharing this great information.
I wonder if the analysis will reveal what type and brand (dino or synthetic) of oil the dealer use.
I just did my oil change at 800 miles on my 09 G37x at the Infinity dealer and they use dyno oil. I have to request synthetic and they use Mobil 1 instead of ester. I will have to purchase my own Nissan ester oil and bring them to my next oil change at 1200 miles. I would like to make sure that they will put them in and not swapping for something cheaper.
Old Jun 26, 2009 | 02:53 PM
w0ady's Avatar
fgc moderator
dont think they can tell you type of oil. dyno oil? nissan ester sucks, who cares. mobil 1 isnt a full synthetic either.
Old Jun 26, 2009 | 03:37 PM
rcdash's Avatar
That's a lot of aluminum - weird. My newly built shortblock from Forged had much lower numbers for just about everything, even on the oil that was used to refill after I blew the oil filter off at the airstrip on a hard run and the car ran without oil for about 10 seconds. That said, whenever I do an oil change, I use Mobil 1 0W-40 mixed with 15W-50 (depending on winter/summer). Whenever it goes to Forged, they use 15W-50 300V, but I've noticed slightly higher metal wear with Motul (not significant probably). Sharif will probably kill me for saying it, but I'd give Mobil 1 0W-40 a shot for one interval and see what happens. You should post up in the my350z stickied oil analysis thread...
Old Jun 28, 2009 | 04:46 PM
djamps's Avatar
I just sent out a sample of motul 5w40 for analysis and then filled with mobil1 5w40 (turbo diesel truck blend) which I will send out as well when the time comes. Will be an interesting comparison.
I hope that the high aluminum doesn't mean you have a possible future O.C. engine (rings)...
Old Jun 28, 2009 | 05:25 PM
superchargedg's Avatar
Mobil1 0w40 european is the only true synthetic by mobil.
Old Dec 30, 2009 | 03:34 PM
Izb's Avatar
Izb
Are you sure that 300V is the best oil for your Nissan?
Old Dec 30, 2009 | 05:50 PM
djamps's Avatar
^^ Doesn't look like your engine is wearing properly. Even with twin turbos I'm very close if not equal to universal average. Even silicon is high on your results...do you have an aftermarket intake that might be letting dirt through?
g.spot
May 9, 2016 10:54 PM
quikrotary
2nd Gen (V36) Sedan
11
Nov 19, 2015 05:14 PM
BradMD_96
Oct 6, 2015 09:31 AM
