sigh....another problem!!
ok so my steering is now making noise's then the wheels are straight and i move the steering wheel back and fourth about an inch or so i hear chreeking from up front and vibration when i do this not sure if its a tire rod end or rack and pin any 1 have or had this problem?
Get someone else to turn the wheel while you look and listen for where the sound is coming from. Make sure your belts are not slipping and that your power steering fluid is topped up. Check for signs of leaking fluid in the engine compartment. You should be able to tell where the sound is coming from and zero in on the problem from there.
itgogitrev
Sep 23, 2015 07:08 PM
