HELP! my car throttles on its own when slowing down.
Old Apr 2, 2009 | 05:34 PM
DaveB's Avatar
Try this before having the dealer do the same exact thing for $100+.
Accelerator Pedal Release Position Learning
1) Leave ACC pedal "as is”
2) Turn IGN switch “ON” – at least 2 sec
3) Turn IGN switch “OFF” – at least 10 sec
4) Turn IGN switch “ON” – at least 2 sec
5) Turn IGN switch “OFF” – at least 10 sec
Wait 10 sec for next procedure
Throttle Valve Closed Position Learning
1) Leave ACC pedal “as is”
2) Turn IGN switch “ON” – appr 3-4 sec
Idle Air Volume Learning
2) Start engine and warm up to operating temp – temp gauge around middle
4) Turn IGN switch “ON” – 3 sec
5) Fully depress and release ACC pedal – 5 times within 5 sec
6) Wait 7 sec
7) Fully depress ACC pedal for appr 20 sec – during this time CEL blinks
8) When CEL light is “ON”, not blinking – fully release ACC pedal
9) Turn the engine “ON” within 3 sec
10) Start engine and idle
11) Wait 20 sec
12) Rev engine 2-3 times and check IDLE
IDLE = 700 rpm
Old Apr 2, 2009 | 06:04 PM
raydeon's Avatar
6) Wait 7 sec
11) Wait 20 sec
IDLE = 700 rpm
what does it do?
Old Apr 2, 2009 | 07:34 PM
dofu's Avatar
20 Year Member
Originally Posted by raydeon
what does it do?
I'm guessing your throttle body froze up a bit or something, and now your car does not know what position the throttle body is. DaveB just showed you how to reset everything so your car can relearn and it stop tripping out by revving itself. It's a perfectly safe procedure...
If this doesn't work, and I do mean if, then I really don't know what it could be. (I can't speak for DaveB)
Old Apr 4, 2009 | 12:36 AM
sliderg35's Avatar
Since you have an 05, you do have rev matching - so when you slow down it will rev match as is goes down through each gear. If this is what's happening, it's all good and you don't have a problem at all.
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
itschuckster
Jul 25, 2015 08:07 AM
