Haltech 350 ECU
Old Apr 1, 2009 | 07:31 PM
CarlosM's Avatar
Haltech 350 ECU
I recently installed a haltech 350 in my 06- G35 6MT. Installation wasn't easy inasmuch as there's almost no space available in the front passenger kick panel area where the factory ECU is located. I want to make use of the "two step rev limiter" using the clutch switch. Is there anyone that can help explaining how to make such connection. Which color coded wire from the 350ECU two pin connector is mated to the wires in the clutch switch. If a relay switch is necessary for this set up, which wires are connected to the switch..
If anyone out there wants to know how to install (or how I installed) the ECU, pls let me know. I also have pics of the installation.
Any help will be appreciated.
Thanks..
Old Apr 2, 2009 | 03:48 PM
_jb's Avatar
_jb
Photographer
Give Hal at Injected a call.
Old Apr 2, 2009 | 11:39 PM
CarlosM's Avatar
I've done that and Hal has been of great help. I was hopping for someone in the forum that might have installed a Haltech and taken pics of the 2 step rev limiter wiring with the clutch switch..
Thanks for your response.
Old Apr 3, 2009 | 07:13 AM
Glex25's Avatar
Administrator
Here is a thread i found that helped me
http://my350z.com/forum/forced-induc...h-control.html
I'm installing it in my car and don't know if i will be able to get to it this weekend
but i will try to take pictures
You also have wiring diagrams here
http://www.injectedperformance.com/haltech/
I have one of the newer Haltech's that already have a breakout for the 2 step apart from other stuff
which makes it so much simpler and you don't have to splice into the wiring harness.
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
g.spot
May 9, 2016 10:54 PM
MThawkins86
Oct 24, 2015 02:07 AM
Kicknshift
Sep 3, 2015 09:35 AM
