bank 1 and 2 running lean?
Old Apr 6, 2009 | 09:02 AM
04Gwhiz's Avatar
well a few days ago a check engine light came on..I ran the diagnostic tool to see the error codes it was bank 1 and 2 are running lean..what does this exactly mean and what are possible causes...more over possible fixes? what can happen to the car if it is left unfixed? can it be hazardous in the long run for the car?
Old Apr 6, 2009 | 11:34 AM
SenorCole86's Avatar
banks refer to the different sides of the engine. It's a V-6, so each bank (the left and right banks) contain 3 cylinders. Running lean can be bad for your car, as fuel acts as a coolant in the combustion process. Running lean means that the air/fuel ratio is higher than it should be, so you do not have enough fuel in the mixture. Your engine will run hotter and you risk burning things up, depending on the severity of the leaning issue. I would take to get it looked at.
Old Apr 7, 2009 | 01:47 AM
M-azing.'s Avatar
i had this same issue mine was an exausht leak with my aftermarket headers after having them on for 7 months, then i put my stock ones back on and its been fine ever since., So it could be as simple an an exausht leak
Thebaws11
Jul 2, 2021 11:36 AM
Vqalexisz
Oct 14, 2015 12:48 AM
joeslates
Sep 11, 2015 11:19 PM
Rhinos7777
Sep 6, 2015 05:36 PM
