Model Years
Old Jul 3, 2004 | 09:55 AM
eldy's Avatar
Model Years
What's up with people posting 2003.5 and 2004.5 as their model years? Are there really cars with stickers on 'em that say that they are .5 years or are people just tryin' to make their car look a bit newer? What VIN ranges do you consider as .5 year models?
Old Jul 3, 2004 | 10:16 AM
dave's Avatar
Re: Model Years
There were mid-year changes in both 2003 and 2004, so 2003.5 and 2004.5 are correct in some cases.
For the 2004 model year, if your coupe's VIN starts with 800001, it is a 2004.5. For the sedan, the 2004.5's start at E*4M600001 or F*4M700001.
I'm not sure about the 2003.5, hopefully someone else does.
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Jul 3, 2004 | 11:21 AM
eldy's Avatar
Re: Model Years
Is there a list of changes for each series?
Old Jul 4, 2004 | 12:41 AM
jstwong's Avatar
Re: Model Years
A good question. Since I have a 2004.5 G35 Sedan, I've been trying to figure out what changes were made to it. I really haven't found out too much to date, other than the 04.5's incorporate a brake fix / alteration. I've asked my friend [who works for Nissan] to see if he could find out for sure what the exact changes for the 04.5's versus the 04's were. He's pretty busy though, but he'll try to take a look.
Old Jul 4, 2004 | 02:57 PM
eldy's Avatar
Re: Model Years
Message me if you find out any more info. Looks like this thread is dying. :>
Old Jul 4, 2004 | 05:32 PM
dave's Avatar
Re: Model Years
There were some threads on the 04.5s a few months back. I believe the consensus was that the 04.5s were ULEV2.
Some said the 04.5s have the new AT shifter ****, some said it was before the 04.5s.
I'm sure there are threads around dec-march that answer this question.
GroundingGear™
2003 Yamaha YZF600R
Old Jul 4, 2004 | 07:21 PM
neffster's Avatar
Re: Model Years
Woohoo and crapola! I just went out to see what I have, the VIN is ...805XXX, that means that I have a 2004.5 but it also means that I cannot get the TS-ECU upgrade yet.
I was planning on getting that when I went on vacation in about 3-4 weeks. Happy and bumbed at the same time.......
<font color=blue>The above statements are only my take on the issue. If you disagree with anything I typed then you are 100% right!</font color=blue>
Old Jul 4, 2004 | 10:45 PM
KPierson's Avatar
Re: Model Years
I think I remember hearing there were emissions changes in the 04.5.
Not sure what kind of changes, but changes none the less...
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Jul 4, 2004 | 10:51 PM
GeoBau's Avatar
Cactus Hugging Admin
Re: Model Years
There were some pretty noticable changes between the 2003 and 2003.5, the most instantly identifiable being the "doggy door" on the trunk converted to the new single-panel design. You can quickly tell the difference between an 03 and an 03.5, however I'm not so sure about the differences between the 04 and 04.5
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
<font color=blue>Z-tube, Pop-charger, Borla True-Dual Exhaust, Eibach Pro Kit, GroundingGear</font color=blue>
Old Jul 5, 2004 | 03:18 AM
deadmanincbh's Avatar
Re: Model Years
Another difference between the 03 and 03.5 is you can now open the trunk from the inside, inside the trunk their is a new design to the interior trunk release system and they also added another power outlet.
Old Jul 7, 2004 | 04:20 PM
GeezerB's Avatar
Re: Model Years
One very noticeable change was to the auto sedan...
When in manual mode, the tranny will not upshift (1st to 2nd, etc) without driver intervention, although it does d/shift as you slow to a stop.
2004.5 DG 5AT SEDAN
Aero Sport Premium
Old Jul 7, 2004 | 07:54 PM
bsgoren's Avatar
Re: Model Years
Yes, they changed the MM mode's operation in the '04.5 model. I was freaking out when I picked mine up and drove it home, thinking it had the old style MM mode (which didn't seem right, IMO) but was releaved when I found it had been changed and works the way MM shifting should.
Until the '04.5 change, the MM mode downshifted for you but it still registered (in the dash) whatever gear you had it in last; so, starting from a light or a stop sign, it would shift automatically (unless you manually downshifted all the way to 1st gear) until it hit the last gear you were in (the MM mode)...it was a bit annoying, especially since our '03 FX35's MM mode didn't operate this way. The FX downshifts for you, but it shows you which gear you go down to in the dash, and the MM mode will always start in 1st gear from a dead stop, which makes more sense for MM mode. That's the point of MM mode -- to shift manually from 1st to whichever gear without a clutch. So, the '04.5 G35 5AT model now reflects this change. I still don't understand the Infiniti engineers' thinking on the old MM shifting????
btw - yes, the '04.5 model also has the shifter with the button in front (toward the windshield) like in the FX.
2004.5 G35-S 5AT Black/Willow - Prem, R. Spoiler, Navi, Infiniti Sport Wheels, Alum Pedals, Dark Tint, Z Tube, K&N Filter<P ID="edit"><FONT class="small"><EM>Edited by bsgoren on 07/07/04 04:59 PM.</EM></FONT></P>
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
