Valve lash adjustment
Old Apr 7, 2009 | 11:02 AM
tcturbo76's Avatar
Does any one know of a good manual or set of proceduers to use to adjust the valve lash on my '04 G35? Preferrably a PDF or link...
Any help is appreciated!
Old Apr 7, 2009 | 11:06 AM
PAIXAO's Avatar
I didn't think this procedure needed to be done until at least 100k. What's the mileage on your G?
Old Apr 7, 2009 | 11:23 AM
tcturbo76's Avatar
80K. But its had a tapping noise for sometime now... probably the last 10k. The weather is nice now and I can work on it...
Old Apr 7, 2009 | 11:27 AM
PAIXAO's Avatar
Have you run BG44 through the tank or BG-MOA in the crankcase?
Old Apr 7, 2009 | 11:54 AM
AARONHL's Avatar
What are the symtoms and what type of procedure is it? I have 95k on my G.
Old Apr 7, 2009 | 05:23 PM
OCG35's Avatar
A valve job on dohc is not typically a diy.
Old Apr 7, 2009 | 05:31 PM
Jeff92se's Avatar
Red Card Crew
To the OP, adjust valve clearances on a VQ35 is not just a matter of turning an adjustment screw.
You have to measure the clearances, remove the camshafts, calculate the new valve lifter size you need, purchase them, install and remeasure the cold and hot clearances again to verify.
Old Apr 7, 2009 | 08:49 PM
tcturbo76's Avatar
I havent put any additives in either the gas or oil.
Old Apr 7, 2009 | 08:54 PM
tcturbo76's Avatar
I have a constant tick on the drivers side of the engine. It speeds up as I accelerate. Im pretty confident its valvetrain noise, but dont have the procedure to assess it or repair it...
Old Apr 7, 2009 | 08:58 PM
PAIXAO's Avatar
If you're looking at doing a valve lash adj yourself I would highly advise against it. First start by running a synthtic oil if you don't already. Then run BG MOA and 44 through the crankcase and gas.
Old Apr 8, 2009 | 07:59 AM
tcturbo76's Avatar
I do run synthetic oil, but have never tried the BG products. I will get the MOA and 44 and try them...
I have the Service Manual, and it does seem like a real S.O.B. to do the valve lash adjustment, but I'm afraid its going to have to be done. I just really dont want to pay the Stealership to do it. Typically, what does the dealer charge for this "adjustment". I had a local Nissan whiz (worked for Nissan dealer for 20 years, started his own shop) look into it and said he wouldnt tear into it for less than $1000!
Old Apr 8, 2009 | 08:06 AM
tcturbo76's Avatar
I see that the lifters come in 27 sizes. Do I order them by the difference in measurment of lifter thickness + out of spec. cold gap, or by the OEM size stamped on each lifter? That part of the procedure has me confused... The rest is just timing and nuts and bolts. I just want to do this once...
Old Apr 8, 2009 | 08:11 AM
tcturbo76's Avatar
Do the "big box" parts stores carry BG products? Or do I need to find a BG dealer in my area?
BTW... I appreciate all of your responses to all of my questions. The info I have gathered is priceless. Its nice to have a place like this to turn to when you need help.
Old Apr 8, 2009 | 12:22 PM
iusman's Avatar
aww man i got the same annoying TAP TAP TAP let me know if the MOA and 44 help out
Old Apr 8, 2009 | 12:33 PM
MikeGrote's Avatar
i wouldnt let it tap like that for too long. with time, depending on how bad it is, it could damage and "mushroom" some engine parts
