HELP !! Oil found in cylinder #2 and oil deposit found on ALL 6 plugs. Now what...
Old Apr 18, 2009 | 10:47 PM
raydeon's Avatar
Exclamation HELP !! Oil found in cylinder #2 and oil deposit found on ALL 6 plugs. Now what...
so i took out my old spark plugs to day and found all 6 of them has oil deposit on it as shown in picture. on the top of that, i also found oil pooling after removing coil pack over in cylinder #2 but not any of the others. I've read the sticky thread and the guy was talking about cylinder #6 getting oil leakage. are we on the same problem?
i have only 39k mileage on my car. full warranty still valid til Dec. 2009.
Old Apr 18, 2009 | 11:04 PM
4drmadness's Avatar
Yup, same problem, try to fix it under powertrain warranty. how many miles do you have on ur car?
Old Apr 19, 2009 | 02:30 AM
Tollboothwilley's Avatar
You are covered 6 yr 70K miles with powertrain and this is power train.
Go get the valve covers replaced under warranty.
Old Apr 19, 2009 | 02:54 AM
jackov's Avatar
Damn, I will check the mine after my new plugs arrive.
Old Apr 19, 2009 | 03:37 AM
jin22gt's Avatar
how hard is this fix if i was suppose to do it by myself?
Also how much is a valve cover?
Old Apr 19, 2009 | 06:34 AM
Blue Dream's Avatar
I drove ttrank's car solo
I would just take it to the dealer. They'll fix it for free and they will put you in a fly loaner for a day. My dealer doesn't charge for the loaner either.
Old Apr 19, 2009 | 11:54 AM
OCG35's Avatar
There is a 10 page thread on the subject:
https://g35driver.com/forums/g35-sed...rranty-up.html
Old Apr 19, 2009 | 05:01 PM
snotf's Avatar
i cant imagine any authorized dealer charging for a loaner under any condtions... i got myself in a coupe for a oil change free of charge.
Old Apr 20, 2009 | 12:27 AM
I did the valve covers myself. You have to remove the intake, upper plenum, lower plenum and then you have access to the valve covers. I painted my new covers before install.
The passenger side valve cover was much harder than the drivers side because of the coolant rail.
All in all it took me like 4-5 hours. I'd give it a 3 of 5 on the wrench category.
Old Apr 20, 2009 | 03:19 AM
jin22gt's Avatar
Do you know how much a valve covers would cost?
also do we need any special tools?
my warrenty is over..
Old Apr 20, 2009 | 01:49 PM
davidm99's Avatar
20 Year Member
Sedan
You can check out here for any OEM infiniti part that you need (http://www.infinitipartsusa.com).
But I did the search for you and here's a link to the valve covers. They are about $200 each and all you really need from what I have read is gasket for the spark plug tube. If this is the case I hope infiniti gets their act together and start to sell these separately.
http://www.infinitipartsusa.com/part...layCatalogid=0
Old Apr 22, 2009 | 05:50 PM
ttrank's Avatar
Grocery getter
Valve covers are easy to swap out. I have taken mine off a few times.
Old Apr 23, 2009 | 02:47 AM
raydeon's Avatar
just changed my friend's 05 coupe's spark plugs today. found same problem. there are oil marks in the tube after removing the coil pack.
gg
Old Apr 23, 2009 | 12:55 PM
OCG35's Avatar
for the seal/gromet problem? Of something else...
Old Apr 23, 2009 | 01:47 PM
Tangerine's Avatar
When I changed my plugs I found a pool of oil on the cylinder closest to driver on the passenger side. It sucks cause I don't have warranty and need to get a new cover. Anyone know how long I would be able to drive it for?
