Strange situation in neutral
Old May 5, 2009 | 10:59 PM
AARONHL's Avatar
I was trying to solve the clicking I am hearing from the rear of my G. I had the rear jacked up (wheels mounted but off the ground) with the right axle removed. The car had been sitting so it was cold. I started the car while in neutral and let it idle. At idle, IN NEUTRAL, the rear left tire was rotating. If I pressed the clutch to the floor the wheel stopped rotating. In first gear it was rotating a little bit faster and continued to speed up when I gave it gas like normal. But, is it normal to have the wheel spinning like that while in neutral???????
Thanks,
Aaron
Old May 6, 2009 | 11:09 AM
Shakuya88's Avatar
There is some internal drag inside the transmission, even in neutral it will spin the wheels when there is no resistance (car lifted) There isn't nearly enough to cause anything to happen when car is on ground.
I don't know if you know, but there is a TSB for the clicking noise. If car is still under warranty get it done at dealer.
Old May 6, 2009 | 11:24 AM
AARONHL's Avatar
Thanks for the reply! So this is completely normal?
Old May 6, 2009 | 10:27 PM
Shakuya88's Avatar
Yepp. Nothing to worry about regarding that.
Old May 6, 2009 | 11:10 PM
AARONHL's Avatar
Cooooool.
magnetism80
Feb 1, 2019 10:00 AM
G35-R
Nov 7, 2015 01:21 PM
JustinMKN1
Sep 18, 2015 03:40 PM
pasjr1972
Sep 1, 2015 10:17 PM
