Camshafts and Vavle Springs
Old May 10, 2009 | 05:51 PM
mikeman2459's Avatar
Im looking to buy some brian crower cams and with the stage 3 cams you need valve springs and retainers. I was wondering how difficult it is to replace the valve springs and cams. If it looks to be too hard ill just go with the stage 2 cams.
Old May 12, 2009 | 06:24 PM
_jb's Avatar
_jb
Photographer
JWT makes a tool to replace the valve springs on the engine while it's in the car... (I think it's JWT)
Replacing cams and/or springs is a big job... I'm not sure I would want a G35 to be my first cam swap...
Old May 12, 2009 | 09:07 PM
how did you do yours? i think im going to stay away from having to replace the springs
Old May 12, 2009 | 11:30 PM
gabe3d's Avatar
Yeah, you might want to think twice about doing this yourself since it changes the dynamics of your engine, therefore requiring you to change your timing.
Old May 12, 2009 | 11:39 PM
Jeff92se's Avatar
Red Card Crew
BTW changing the springs isn't the hard part (although it is an involved process), it's getting the right bucket shims so the valvetrain doesn't tick like crazy.
Old May 12, 2009 | 11:49 PM
_jb's Avatar
_jb
Photographer
I bought a spare engine and had it built... Then later swapped it into the car...
Old May 13, 2009 | 03:21 PM
sharif@forged's Avatar
As a general rule, you should upgrade springs while installing most camshafts. It's a challenging job for sure...not easy. We usually remove the whole front of the car, for easier access, but still expect about 18hrs at most shops. Unless you are really experienced, trying this at home is not advisable. If this was an Evo or a Honda....go for it.
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
