Which Engine Oil good for 2003 G Sedan
Old May 12, 2009 | 09:46 AM
hkuwhlc's Avatar
May I know which brand do you guys use?
I am using Motul V300 10w-40...is it good? Thanks~~
Old May 12, 2009 | 11:57 AM
vincentl's Avatar
Location, Location, Location.
5w30 or 0w30 (some operation temp) but, Location.
Old May 12, 2009 | 12:02 PM
WILLIE BEANS's Avatar
everyones opinion is different ..
i use mobil 1 sythetic .. its a daily driver .. so no need for anything fancy ..
i change it at about every 3000 miles..
Old May 12, 2009 | 12:10 PM
Swivel's Avatar
Moderator
Search, Grasshopper. Many many threads on this.
Consensus is the top 3 are probably Amsoil (my personal choice), German Castrol and Mobil1. However, if you change oil and filter every 3000, it doesn't really matter.
Old May 12, 2009 | 12:14 PM
Jeff92se's Avatar
Red Card Crew
The oily kind. The oilier the better
Old May 12, 2009 | 04:33 PM
IPGSEDAN's Avatar
Im using 10w-30 is this ok im in California.
Los angeles to be exact.
Old May 12, 2009 | 04:58 PM
mikeee2's Avatar
Just got a case (6 qts of Mobile 1 Synthetic 5w30) at BJ's wholesale for $35.99 - $10 instant off (with coupon) = $25.99
Damn cheap for 6 quarts. Walmart sells 5 quart jugs for $26.
Old May 12, 2009 | 05:54 PM
Mustang5L5's Avatar
I run Castrol Conventional ever since i was 16.
I've never jumped on the Synthetic motor oils. I've never quite bought into the fact that it's that much better
Old May 12, 2009 | 08:04 PM
TheTick's Avatar
I'm in Granada Hills and 10w30 is good for out here. If you ever move to a state that has below freezing weather, switch to 5w30.
Change it every 3k miles and it doesn't matter what oil you use. I use mobil 1 every 7500 miles. If you want to go more than 10k miles you may want to use the higher end oils mentioned above.
Old May 12, 2009 | 09:04 PM
ttrank's Avatar
Grocery getter
M1 15w50 and my car takes ~7qts. Oil changes are not cheap.
Old May 13, 2009 | 01:01 PM
hkuwhlc's Avatar
thank you guys....i live in Hong Kong, quite high humidity and hot in summer...thank you....
Hasanbaloch
Feb 29, 2024 08:45 PM
Augy
Steering & Suspension
Sep 8, 2015 12:53 AM
julian.dion
Jul 29, 2015 09:16 AM
Rehman2009
Jul 27, 2015 03:23 AM
Tom_P
Jul 24, 2015 04:05 PM
