Replacing Spark Plugs
Old Jun 28, 2009 | 04:34 PM
  #31
OCG35's Avatar
^^^ yes, it’s a well-known and multi-documented problem (in other threads in addition to the one you posted).
But I didn’t think a TSB had been released... that sure would make replacement much easier though.
Old Jun 28, 2009 | 10:19 PM
  #32
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by The next best
Thanks
Ill change them.
BTW have you seen my sig lol
hahaha "dropp the BBBB!!!" lol
I am honored. I mentioned that in a thread last week sometime. It was one of those thoughts that just came out. No thinking involved!!
Old Jun 28, 2009 | 10:28 PM
  #33
IPGSEDAN's Avatar
Yeah i forgot what thread it was i never went back to it but i was dying when you wrote this. I mean i dont know you but i could imagine you saying it. "now you need to drop that BBB" hahahaha
Old Jun 29, 2009 | 12:00 AM
  #34
lexusk8's Avatar
Originally Posted by Mustang5L5
Oil soaked on the top?? I thin your VC's are leaking then. There is a TSB, but i think you are past your powertrain warranty
Yeah I already got the VC replaced under warranty before the spark plug change. There was just a little bit of oil pooled on spark plug tube #6 but I believe that was old oil (black) before the VC was replaced. All of the other tubes are dry. I've since removed the oil out from #6, and probably after a couple thousand miles, I'll re-check that spark plug tube for any oil leaks.
Old Jun 29, 2009 | 12:35 AM
  #35
Wannabe6MT's Avatar
-MN G Crew-
How often should you replace your spark plugs? 100k miles? Mine has 50k now...
Old Jun 29, 2009 | 02:29 AM
  #36
ttrank's Avatar
Grocery getter
I replace mine every year but my motor is not the normal sedan setup and I run copper plugs. If I was N/A I would go every 30k to be safe. If you drive extra nice, every 60k.
Old Jun 29, 2009 | 08:28 AM
  #37
Mustang5L5's Avatar
They say plats can go 100K, but every 100K mile plat plug i've seen looks like junk.
I usually say around 60-70K miles you should really consider it. I might do mine at 50K just to check the VC's for oil pooling. But honestly replacing plats around 50K is kinda of just more for peace of mind.
I run copper plugs in my Mustang since it's a better conductor, but change those out yearly. I prob put 4000 miles on them. Copper and Silver plugs are a better conductor of electricity...but they don't last nearly as long as plat/iridium.
I might try some silver plugs for the hell of it
http://www.nology.com/silver.html
Old Jul 7, 2009 | 11:46 PM
  #38
mifesto's Avatar
Anyone run Bosch PlatinumIR Fusion Spark Plugs (FGR8MQI) on an HR motor g35?
Terry_G35
May 9, 2020 01:39 AM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
ghost_g35
Aug 7, 2015 10:31 AM
Terry_G35
Aug 4, 2015 02:38 PM
