engine or transmission problem?
Old Jul 15, 2009 | 10:20 PM
RaginRaj11's Avatar
A couple days ago i started noticing that after about 10 mins of driving the car loses power from 3k-5k rpm. The rpm increases but the speed doesnt increase like it used to and it seems like the car is choking. I have a severe OC problem too. Anybody know what it could be?
Old Jul 16, 2009 | 12:31 AM
foxx_good's Avatar
Could be a lot of things, 1 is it very very hot out? could be the throttle body also does it rev normally before that mark? Your temperature is fine? I see you have a spacer too make sure your bolts are torqued down or once the manifold heats up it could be leaking
Old Jul 16, 2009 | 12:02 PM
RaginRaj11's Avatar
Is it hasnt been too hot. The car runs normal before it hits 3k rpms. Temp is fine. I dont have the spacer anymore.
Old Jul 16, 2009 | 04:28 PM
RaginRaj11's Avatar
I noticed that when im driving normally the car runs fine. The minute i start driving aggressive in manual mode or drive the car starts acting funny. It doesnt pull like it used to after 3k rpms. The car hesitates.
Old Jul 16, 2009 | 04:32 PM
thescreensavers's Avatar
Mr.202?
slipping clutch? I dont know anything but I think thats what happens when you have that :O
google it to find out more info
Old Jul 16, 2009 | 05:25 PM
RaginRaj11's Avatar
i have an automatic though
Old Jul 16, 2009 | 07:03 PM
Mr.202?
ok well I searched google for you for a sec even though maybe you should of.
any how Automatics do have clutches but the slip might happen during shifts. Does it slip when it shifts or only when just accelerating in gear?
Old Jul 16, 2009 | 08:45 PM
RaginRaj11's Avatar
I searched google but i didnt get a chance to post.
It feels like its slipping after i shift the gear and it continues to slip until i change gears. 3rd gear feels the worst though. The car will not pull like it did in that gear. Im still under powertrain warranty so ill have Infiniti check it out.
Old Jul 16, 2009 | 08:50 PM
Mr.202?
oh yea something to do with your transmission I guess if its slipping when changing gears and such. Google "Automatic Transmission slipping" I guess you can find more info that way. But yea defiantly take it in asap.
Old Jul 16, 2009 | 09:43 PM
RaginRaj11's Avatar
cool, thanks man
Old Jul 20, 2009 | 03:05 PM
RaginRaj11's Avatar
could old transmission fluid be causing this problem?
andyg35c1
Aug 29, 2015 03:37 PM
derres
Aug 28, 2015 03:27 PM
saskicker32
Aug 11, 2015 02:12 PM
wuppiedog
Aug 7, 2015 11:16 AM
newg37
Jul 26, 2015 09:32 AM
