Upgraded Aluminum Radiators
Old Aug 5, 2009 | 12:59 AM
  #46
Nickk6's Avatar
lol for 400 bucks I wasn't interested in stealens. I heard some good things about mishimoto from a guy who put some in skylines so I think it will be fine, fitment is horrible, but the quality isn't bad at all. Its decent and I also heard Koyo quality was dropping so this was the way to go.
Sorry for the mislabel in that previous post. But I did mention the G had the biggest radiator so if you were following you knew what was up
Old Aug 5, 2009 | 01:56 AM
  #47
Law to the Rence's Avatar
Originally Posted by Tollboothwilley
I wish they had one with a built in AT cooler...
you can try retrofitting,
i have a koyo with a Z33 power steering fluid cooler as my ATF cooler
Old Aug 5, 2009 | 02:02 AM
  #48
Tollboothwilley's Avatar
Oh, I know that I could just run an aftermarket ATF cooler. I am planning on installing one anyways, I just would rather have one in the rad as well, dual function. Helps to warm the fluid as well as cool it.
Old Aug 5, 2009 | 02:13 AM
  #49
bigc's Avatar
Wings Nation
^ tranny fluid will get warm on its own surprisingly quick
Old Aug 5, 2009 | 03:10 AM
  #50
yeea tell me about it
i actually ran without a cooler for a week
the smells and the temperature...felt like i was sittin in a gutted car
Old Aug 5, 2009 | 12:42 PM
  #51
OCG35's Avatar
Originally Posted by rookie
Thanks - I was looking under sedan (from the browse by vehicle menu)...
Anyone have experience with this?...
I know Dave (black sedan, forgot his screen name) has one... are you in here?
Old Aug 6, 2009 | 01:47 AM
  #52
I know that it will in summer...
I'm in Utah in the winters. Cold Cold winters and sometimes my car is outside.
I need the faster warm up. The motor doesn't even warm up for about 5 min most mornings.
Old Aug 13, 2009 | 04:13 PM
  #53
seankim513's Avatar
don't get the stillen radiator i had about 3 month bottom core is leak. i can not found where's leak but once a while open the hood there's green .fit ment is ok you don't need cut fan suround but you need cut intake alot even stillen.not worth money get cheaper one works same and stillen is not made in usa just **** brand from over sea . $400 not worth don't try.they haver **** warrantee you have take picture and waiting long long time.
Old Aug 13, 2009 | 04:49 PM
  #54
snotf's Avatar
Uhhhh....
Wat?
Old Aug 13, 2009 | 11:44 PM
  #55
I think his korean doesn't come out in English very well.
He has had a stillen rad for about 3 months and it started leaking out the bottom. They have a warranty that takes forever to fill a claim. Fitment wasn't good.
Old Nov 9, 2009 | 08:32 PM
  #56
str8dum1's Avatar
i can tell you guys that the Mishimoto radiator for the G35 still fits like crap. Alot of modification to make it fit. I had to drill new holes and hack up the radiator support to get it to fit. Not to mention that horrible QC from Mishimoto. My weld tabs were in the wrong spots, they welded the wrong sized flange...
Look at the size difference between the "same" tabs
But once in, you notice how huge it is compared to stock. Hope it doesnt leak..
Old Nov 10, 2009 | 05:07 PM
  #57
Nickk6's Avatar
Damn dude, yours does fit bad. The top and bottom tabs are about 3/16 of an inch off, basically spread farther apart then oems. But it fit in fine none the less, however I wasn't trying to use the OEM fan shroud, I used Mishimoto slim fans that mount directly onto the radiator.
KruZZe
Feb 27, 2023 05:04 PM
BradMD_96
Oct 6, 2015 09:31 AM
NyCrAzY
Oct 1, 2015 09:19 AM
blnewt
Sep 25, 2015 01:48 PM
