Long Weekend: Headers, Coolant Pipe Mods, and Nismo Thermostat.
Old Aug 17, 2009 | 04:24 PM
sexyrob's Avatar
So this weekend I got into a pretty big project. Against everyones suggestions to Z/G users I installed headers. it was not the big PITA that everyone was saying it was. It was by no means easy but not nearly as hard as everyone was making it out to be.
Doing everything I did took around 10 hours. probably would have only taken 6 for just the headers but I had to do the coolant pipes and Nismo thermostat and figured while I was in there I'd paint the reservoir. Also the hardest part was removing the rear coolant pipe, we could have saved over an hour by leaving that thing alone.
Suggestions if you plan to do the install: Drink lots of water, eat when you are hungry. Take your time, don't rush. Don't leave things installed thinking you can work around them, you'll probably waste more time in the process. Leave the O2 sensors on the cats/headers, just disconnect the wiring harness from them and once you get them off hit it with some wd40 and use a cresent wrench so you dont have to buy those stupid o2 sensor sockets.
The worst part of this install was probably getting the damn hoses off the pipes... that is so damn frustrating for me. The scariest part was burping the coolant, right when I thought I had all the bubles out I take it on the highway and the temp guage jumps into the hot section and I freak and pull over and let it cool down. burp it one more time and its good
I was able to fully torque 5/6 header bolts with my 20" long 3/8 drive torque wrench.
Got the headers on ebay used (~500 miles on them) for $230 shipped. They are Strup, they are also thermal coated.
Sound is better, got some deeper notes out of it... Feels like I got some more midrange power, don't feel any loss. Seems like it added some rasp under hard acceleration before they are all warmed up
-FYI-
1. Supporting mods: Z-tube, K&N filter, AAM High-Flow cats, Bassani Full cat back, Osiris e-tuned before the headers (probably get this updated now that I have them on)
2. Paint on the coolant pipes was done with rattle cans, I used the High temp paints you can get at automotive stores.
3. I don't have a dyno and haven't dynoed since I got it. I don't want to pay for the excitement or disappointment that can be had by putting it on just yet.
4. This was done on jack stands in case you cant tell.
taped off and ready to be painted
Primed
Painted
Rear pipes compared
Driver side compared
Passenger side compared
Nismo Thermostat
Painted resovoirs
Old Aug 17, 2009 | 04:27 PM
sexyrob's Avatar
Removed grill, bumper, headlight, wheels, splash guards, under-aero parts
Draining coolant
Removed intake, upper and lower plenums
Removed driver side header compared to new
Driver side installed
Passenger side
Installed
Old Aug 17, 2009 | 04:44 PM
visibiliti's Avatar
cool cool.. taking a break from the light project i see
Old Aug 17, 2009 | 04:54 PM
Boston's Avatar
Nice work. Did your thermostat open right away? Just curious as when we did my coolant delete mod it took a while for the thermostat to open and pressurize the system even after we burped it.
Old Aug 17, 2009 | 06:57 PM
sexyrob's Avatar
visibiliti: yeah had a friend available this weekend so I did this while he was around. put the lights on hold... Not happy how long those are taking me but I'm somewhat meticulous. (also I baked the passenger side light and 2 led's died so I have to pull that apart and try again )
Boston: not sure... the engine got pretty hot (temp gauge went past the middle) in the beginning so maybe it wasn't opening. I drove around all day and it was rock solid the car-thermometer says 106 today so its nice to see the engine temp normal (maybe slightly lower, not sure though) Did have one issue today though, I was sitting in a parking lot for like 20 minutes and the temp kept rising, not sure if the fans weren't kicking on or what but I killed the engine and sat for 10 min, then when I drove around everything was good again.
Old Aug 17, 2009 | 08:02 PM
OCG35's Avatar
cool!
I need to paint my coolant pipe (just the straight one on pass side)... recent wire tuck makes that stick out like a sore thumb!
Old Aug 17, 2009 | 08:03 PM
CandlestickPark's Avatar
ill Sedan
Nice work dude.
Originally Posted by OCG35
cool!
I'm modding mine too Mike. Chris already did his.
Old Aug 17, 2009 | 08:24 PM
drifts500's Avatar
Wow!! very good! I want to here the exhaust with that headers on!.
Old Aug 17, 2009 | 08:28 PM
OCG35's Avatar
Nice work dude.
PC, chome, or paint?... I'm thinking either black chrome or PC black
Old Aug 17, 2009 | 08:32 PM
Johnnyone's Avatar
Good find on the header, they look good. Be interesting to see how they perform and hold up.
Old Aug 17, 2009 | 08:44 PM
thatguy II's Avatar
I have a freebie set of strup headers just waiting for me
OP, couple questions about the install.
Did you have to break apart the steering linkage? Most of the directions I've seen say to...
Were you able to get them in and out from the topside?
Old Aug 17, 2009 | 08:54 PM
sexyrob's Avatar
thatguy II: yeah I loosened the steering linkage and just slid it up and the bar moved enough to get them it, its no big deal I didn't mark it or anything since the steering wheel locked it wouldn't move. Headers go in through the bottom. It's good to have 2 people who know what they are doing, makes things go much faster.
also, I'm in the process of putting together some videos I have... took some sound after each mod...
1. Bassani Exhaust
2. Bassani + AAM High flow cats
3. Bassani + Cats + Strup Headers
Old Aug 18, 2009 | 11:49 AM
GreenGoblin's Avatar
The goblin resurrection
My jet hot coated bloody knuckle headers
Old Aug 18, 2009 | 03:49 PM
rpm06g35's Avatar
Man looks good Yeah burping this thing is not good for the weak. It scares the pi$$ out of the owners all the time.I"M IN THE RED MAN I"M IN THE RED.hahaha Cool mod though. Glad to see it worked out.
Old Aug 18, 2009 | 03:50 PM
ill Sedan
You already know the answer to this one...if its going in my bay you know it it'll be chrome
